Old 04-11-2008, 02:09 PM
isx_frontier's Avatar
help!! how to take off the headlamp for 1st gen 1.2
hi!!! i just had a bulb burned out and i have nissan frontier 2002 XEV6 and i tried taking off the headlamp myself. however, when i took off like 3 nuts i found out that theres like a clip holding the underneath of the headlight housing.
how do you guys take it off? i tried prying it but i was wondering the plastic might crack.
please!!!! help!!!
help!!! anyone???? please!!!
nismo bilstein spec shocks, NGK iridium sparkplugs and NGK wires, HID kit, k&n intake, flowmaster exhaust, JBA exhaust tip, westin pushbar with HELLA 500 daylighter, wade vent visor stock s/c
Last edited by isx_frontier : 04-11-2008 at 02:26 PM. Reason: Automerged Doublepost
Old 04-11-2008, 02:35 PM
steve0616's Avatar
They should just pull straight out after the two bolts are out. There is one clip on the bottom.
2004 Electric Blue CC SB LE:
Old 04-11-2008, 02:37 PM
I just had to do this on mine. Take out the two bolts and give it a good tug. There's a couple of clips holding the bottom.
2003 Crew Cab S/C 4x2, Sand Dune
Old 04-11-2008, 03:06 PM
Supralative's Avatar
Send a message via AIM to Supralative Send a message via Yahoo to Supralative
I took out the top two bolts.
Got underneath the truck and use a panel clip driver to pop out the lower section.
Son N.
2.5in Lift with Front TB crank, Rear AAL
Rancho RS5000's all around,
18X9 Pro Comp Forged Stryker metallic black,
285/60/18 Nitto Terra Grapplers, K&N intake,
Setrab Transmission Cooler 8 1/4 X 2 X 5 3/4
Blacked out lights, Full entertainment set up
Old 04-11-2008, 04:12 PM
the clip will not crack right?? just pull it straight forward?? ok.. i'll try it!
Old 04-11-2008, 05:19 PM
XE_KING's Avatar
this may be a dumb question, but ill ask it anyway... What the he!! are you taking the whole housing out for?? The bulb inserts brom the back of the housing. There is a keeper that you turn like a half twist then out comes the bulb.. Unplug it from the wire harness install new bulb w/out touching the glass and your done.
-Nick-
01 XE King Cab, V6 4X4 ,5 Speed, K&N filter w/air box mod,Clutch switch starter button mod,EGR bed rail caps, Optima Yellow Top, Hyper White Headlights, 2.5" Rancho Lift, Rancho 5000's Bumper To Bumper. Pioneer premier deck, Focal separates with a Alpine amp, Alpine type R 12" sub with Rockford Fosgate 1000w amp W/ a 1 farad cap. ROCKS!!!
Old 04-11-2008, 05:39 PM
let me know how you are going to replace the parking bulb....
Old 04-11-2008, 05:53 PM
XE_KING's Avatar
please!!!! help!!!
You show me where you said anything about a parking lamp in here...??Not trying to be mean.. just raised the question in my mind
Yes those parking lamps are tricky little things though....
-Nick-
Old 04-15-2008, 11:53 PM
jonblazed's Avatar
you can replace bulb without taking out the headlight buddy.
2002 CC: Nismo Exhaust, Nismo/Bilstein shocks, Nismo intake,Blacked out Halo lights, Coach interior and 2002 black S2000: stock
Old 04-16-2008, 07:01 PM
ochsbeatdown's Avatar
Send a message via AIM to ochsbeatdown
not the parking one. when mine burnt out i had to take the entire housing off, and it was such a *****. theres NO WAY to get around not taking it out to replace the two side markers
2001 Nissan Frontier XE 5-spd
-Kenwood KDC MP732 headunit with iPod adapter
-Alpine SPS-17C2 6.5 inch door speakers
Blaupunkt Thb 200A sub
-Truxedo Truxport Tonneau Cover
Rutgers University '09
