Old 08-27-2008, 11:39 PM
Pro2X's Avatar
I would go back tell him those are the correct UCA's and that they overcharged you. Tell them you called over shops in town and go a quote on alignments and they all gave you a quote of xx didnt matter how long it took them. Also, charging you for a camber bolt that they broke. Hell no, tell them that was a brand new one from nissan and they will uncharge you for that amount + buy you another one and install it. Stand your ground. They are bullcrapping you out of it and making it look like you know nothing about your truck. Go in there with confidence that you know what your doing and they dont. if they have a manager or a higher up talk to them. Was it a place like firestone or something or just a family owned shop?
Also, about that bolt....no way in hell they broke that bolt unless they did some off the wall crazy stunt. ask them how to break a grade 8 bolt. once they say its pretty impossible then say how did you break mine? Im pissed and it didnt even happen to me. lol
1 day, Pro2x will be completed...
Performance: nismo cai, tbs, ims, ground kit, coolant bypass mod, optima yellow top, d. thorley headers, all 4 cats removed, magnaflow muffler, and new piping
Exterior: tinted windows, black billet grill, colormatched headlights, fiberglass bed cover
Interior: pathfinder switch mod, katskin 2 tone leather, KW-AVX706 dvd/cd, Sundown 1500d, JL 300.4, JL12w6v2, Polk Audio Momo 6.5 comp/6.5 coaxials
Suspension: cst 4" spindles,prg 3" spacers, Alcan 8 leaf pack, extended saw shocks, extended ss brake lines
Wheels/Tires: pro comp 7189's with nitto tg 295/75/16
Offroad: m226 swap, titan alum diff cover, mag hytec seal, ac diff skid
I will support Barack Obama as much as everyone supported George W. Bush!
Old 08-27-2008, 11:44 PM
bigdog's Avatar
you should call greg at PRG and get his $.02 The price seems ridiculous, but the real question is alignment.
2006 SE CC 4x4 A/T:
Old 08-28-2008, 01:46 AM
XE_KING's Avatar
yeah. the fact that they didnt even get the thing done is f***** up! lol you pay for the job that is quoted in the computer. it is illegal for them to charge you more just because they are retarded!! They should pay you at this point... I had a vw that I took in to get belts done(had to pull the pullys to do this) quoted in the computer at a 30 min job..well it took the tard about 4 hrs.. they tried to charge me for the time. First I told them to go get Fu#ked... then I told them I would call the better business bureau... I didnt pay a dime...
-Nick-
F.W.O West Coast Chapter
Old 08-28-2008, 12:26 PM
fusionfronty99's Avatar
i know what your problem is
either A you have bad lower BJs
or B, the holes in the frame where the chamber bolts go threw are ripped and stretched
mine right now are "tore" on my rear drivers side not allowing for a perfect alignment
its no so much that the bracket for the UCA is cracked and its a safety hazzard, its more of the oval hole is ground and ripped out more allowing more movement of the chamber bolt than what it the eccentric discs can allow
UCA Mount Question
-Josh-
99 Nissan Frontier XE V6 4X4
AC, Calmini, Ballistic Fab, Bilstien, KC, Shrockworks, BFG, L&P, SLR, Copperhead Fab, Pro Comp, Cherrybomb, K&N
Yeah, it's the new king of everything,
and b*tches don't say no to me, I'm like a wedding ring.
Old 08-28-2008, 02:58 PM
2WD_NISMO's Avatar
Crazy...they should have called you for autorization for extra expenses, something that I thought was SOP in the auto repair biz..."WTF" indeed!
Two WD '05 NISMO: JBA Cat Back, NISMO CAI, E-fan, WRP IMS, WRP Pulley, LED Talis + 3rd...and?
Old 08-28-2008, 08:28 PM
NISLO's Avatar
wow, we charge 69.95 for any alignment at any length of time. Unless eccentric bolts need to be added for the 2nd gens. Then the customer just pays for the parts and the alignment fee. Go raise hell and get your money back, if you can't do it bring a friend that can.
[font="System"][b][size="2"]Your friendly neighborhood nissan master tech- Vote For me TOTM Nov http://www.clubfrontier.org/forums/f...-pt-2-a-37265/
Old 08-28-2008, 08:38 PM
Sly Tuna's Avatar
Thats some mest up ****. Tell him to buy you a new bolt set, redeem your money, and you're taking your business somewhere else. I do know that the 1st gens are harder to align with the torsion bars and everything. Especially if you have them cranked all the way. Thats also a possibility
06 Nissan Frontier XE KC 5 spd.
Wheels: (Titan 18" 6 spokes)(1.5 spacer/adapters) Rear: (10 leaf deaver leaf pack)(2.25 Sway-a-way Res. shocks)( Front: (Cst 4" spindles)(PRG Heim UCA's)(2.5" Sway-a-way Coil overs 625 LB springs)(NO Sway Bar) (SS Brake Lines) Performance: (WRP Crank Pulley)(Cone Filter on air box)(6 wire grounding kit)(Electric fan)(22" Cherry bomb glass pack muffler) Visual: (painted: Front bumper, grille, door handles, mirrors)(red Calipers) De-Badged)(No Bed liner) Sound: (Pioneer HU)(kenwood amp 500 RMS)(Alpine Type R sub 500RMS)(custom 1.5 Cubic foot carpeted enclosure)(stock speakers)
Old 08-28-2008, 08:46 PM
XE_KING's Avatar
I know I had to be sure and tell them not to mess with my T-Bars.. because that is the first thing they will do ... lower those babys back to stock.. makes it easier to allign.... This makes me mad... I want to yell at them for you.... I really hope you can collect your nuts and get your money back... sucks man....
-Nick-
