Old 08-14-2008, 09:38 AM
slow95tsi's Avatar
going up
Hi guys & girls I have an 01 crew cab that I am thinking about lifting.
What are my choices for a suspension lift ? I'm not a fan of a body lift, they look silly in most applications.
Could anyone post a couple pics of their lifts with size & brand please?
I am thinking something like a 2 - 3 inch lift for mine.
Thanks
Patrick
Old 08-14-2008, 02:21 PM
Hertz's Avatar
3 inch from Automotive customizers (4x4parts.com) 31's in the picture but it has 32s now.
theres more in my gallery.
Old 08-14-2008, 03:04 PM
adorsey's Avatar
You can do a PML which is a single aal or shackles and a t-bar crank. The single aal will give you about 2" of lift in the rear and shackles give you about 1" maybe 1.5". You can also buy a full package from AC or Calmini. Thoses "lift kits" include UCAs, AAL and or shackles shocks and other goodies. You have a wide range of stuff to chose from.
2000 KC Desert Runner V6, AAL, Calmini Shackles, Calmini UCA's, Rancho 5000s all around, Bilstein Steering Stabilizer, AC idler arm brace, 31" BFG A/T, K&N CAI,
Flowmaster 50 SUV,WRP Grounding Kit, NGK Plugs and Wires, Silverstars, AVS Ventshades, 20% tint, Headunit, 600w amp, 12" sub, Door Speakers
Old 08-14-2008, 04:03 PM
VeS206's Avatar
I have Calmini's 3inch suspenion lift. I think its a great but just a little too stiff in the front tho. Other then that. The nost you can do on a 1st Gen is 3inch suspension and/or 2-3inch body. Unless you go custom. Hope this helps.
2003 Supercharged' Mall Crawler....
Old 08-14-2008, 04:54 PM
adorsey's Avatar
If you want more than 3" suspension, better go with SAS.
Old 08-14-2008, 09:50 PM
fronty2wd's Avatar
Yes do a sas it's the latest craze.
Old 08-15-2008, 11:17 AM
slow95tsi's Avatar
What is an SAS ? Will it give a better ride on the highway ?
Hertz do you have any other pics of your truck? I think that is about the stance I am looking for.
I am not looking for anything to big. I drive the truck a lot and want to keep it comfortable. I already have a Jeep I lifted with a spring over and shackle reversal that is my off road toy. Just trying to get the Frontier a little bit bigger, I have LT 265/75R16's on it that are just a hair over 31". They look just a little big for the wells.
Here is my play toy
Old 08-15-2008, 12:26 PM
Send a message via AIM to tsacain
A sas is putting an axle like the one under the front of your jeep into your frontier. It would ride like your jeep on the highway most likely. I would just stick with a 3 inch lift from AC or total chaos.
Kevin
2002 Silver DR
with a few mods
Old 08-15-2008, 02:18 PM
Hertz's Avatar
the TC lift is WAY too expensive if you only want "a better stance".
and here are some more pictures, they're pretty old. since them ive put a roll bar in and 32 inch bfg mt's.
Old 08-15-2008, 09:33 PM
pbh114's Avatar
Another choice is Calmini. Not necessarily better or worse than AC, but it gives you something else to look at. I have theirs, and cranked the t-bars up, probably a little too much. Here's a pic, but I have a 3" body lift and 33's so it won't be nearly that high.
'00 XE CC V6, 3" body lift, Calmini UCA's, add-a-leaf in the rear, bronze Nismo wheels, 285/75R16 Nitto Teragrapplers, AEM Brute Force CAI, Nismo exhaust, ultra low-pro upper UCA bump stops, Bilstein steering stabilizer, AC idler arm brace, AVS Ventshades and Bugflector, Viair 350c air system with 150dB Siege Engineering Hammer 3 Air horn
