Old 09-18-2007, 01:58 PM
TUFFTOY's Avatar
Exclamation Which fuse?!?!?!?!
I lost the light from the dash! The light that illuminate the speedometer, the lights that illuminate that heating console and when I take the keys out and open the door leaving the lights on the sounding beeping alram doesn't come on.
It's probably a fuse but which one???
I removed and visually inspected everyone from under the driver's side dash and the other little fuses under the hood next to the battery.
There are other big fuses in that compartment that I don't know how to check, could it be one of those?
Old 11-21-2007, 02:15 AM
01yzf600r's Avatar
Why did your lights go out?? mine was when I put the D3 in.
2002 Nissan Frontier Crew Cab 4x4 5spd, power, sport, and audio packages, Calmini lift and 32" all terrains, (photo shows 33" mud terrains)
http://2wm.org/Default.aspx?tabid=61
Old 11-21-2007, 02:24 AM
beefy242's Avatar
are you sure that you didnt just accidentally mess with the gauge dimmer?
i think that its one of the ones inside the cab... not 100% on that though.
cardomain page:
Old 11-21-2007, 03:01 AM
01yzf600r's Avatar
What is a gauge dimmer?
WTF, I know it gets over looked, But come on!
I have checked almost all the fuses and can't find it.
Maybe I am not turning the dimmer hard enough, I have turned it all the way up, and all the way down, then back up. want to try it?
Sorry I am just a little frusterated!!!!!!
Old 11-21-2007, 03:25 AM
beefy242's Avatar
gauge dimmer: used to dim your gauges!!!!
you rotate it to adjust the brightness of the backlight on your gauges, so you dont get distraced or whatever.
but try the fuses underhood as well.
cardomain page:
Old 11-21-2007, 06:23 AM
silversuper's Avatar
again wiht the noobs and the multiple threads
Richie, i love mozilla
www.linxc.com
2001 silver SC CC
Old 11-21-2007, 11:07 AM
fusionfronty99's Avatar
yooooo my gauge lights are out too, has to be a fuse, but like him, i dont know which one, nissan didnt label the fuses to well
-Josh-
99 Nissan Frontier XE V6 4X4
AC, Calmini, Ballistic Fab, Bilstien, KC, Shrockworks, BFG, L&P, SLR, Copperhead Fab, Pro Comp, Cherrybomb, K&N
Yeah, it's the new king of everything,
and b*tches don't say no to me, I'm like a wedding ring.
Old 11-21-2007, 12:07 PM
A few years back I remember a few people that had issues with the dimmer switches failing. I do not remember if the Smart Entrance Control Unit takes an input from the dash light circuit (The SECU is the box with the chime in it). If your power door locks work then the SECU is getting power. I will have to check on the diagrams when I get home.
The Sleeper: Waking up at a trailhead near YOU!
It has more mods than I can count or fit on this page. Most of you have a long way to go to catch up... LOL
Old 11-21-2007, 02:37 PM
01yzf600r's Avatar
I am pretty sure the doors lock, I thought I heard them when I pressed the button?? ( I will check 4 sure)
My parking lights and tail lights work and I checked those fuses?
I checked the horn, I checked the lighter, dome lights work???
Like I said I just put an avic-d3 head unit in. I have a Rockford fosgate truck and the stock wiring was diffrent then the generic wiring harness. I have a purple wire on the stock side that powers the amp, on the aftermarket side it was a speaker wire. I had to jump the blue amp relay from the other aftermarket harness to that stock purple wire, then I had sound.
I also wired the dimmer and illumination to the orange on the pioneer and plugged everything in, this is when I blew the fuse and or panel? I called the tech at "best buy" I have now cut the dimmer wire. (this is all on the after market harness).
And the other problem, My stock deck had 3 harness plugs the after market kit only came with 2?
My question is Nissan would not have wired the dash lights to get power from the deck would they? what do those yellow wires on the third plug go to? I was told just not to use them.
I have checked all my wiring from the head unit install, I am sure it is correct and grounded. I know this because I unplugged all the after market stuff and replaced it with stock and still no dice. (I have not cut or damaged any of the stock wires or harness)
Old 11-22-2007, 01:20 AM
beefy242's Avatar
didnt label them well? they did a HORRIBLE job and personally, i could be looking at a map of the process for cold fusion (which is still a theory) in Russian and have the same understanding for which fuses go where.
just pull each one out, one at a time, and then maybe just maybe you will find the right one.
oh and i know that youre trying to cover all the bases and whatever, but please, dont pull crap with like 3 threads in different places, 01yzf...?
cardomain page:
