I want to add fog lights to my 2002 Frontier XE.
Does anyone know if the XE model has the proper hookups for the fogs?
Any recommendations for aftermarket fogs or OE?
I also want to add cruise control. I know Nissan does not have a factory add-on for cruise, any recommendations?
my XE king cab had no hook ups. i just bought a set of PIAA 510 driving lights and threw them in. much better option then putting ebay or nissan fog lights in. they push light out easily close to 1/2-1 mile in distance. theres no flat spots where i live so i couldn't give you a honest as to how far they could really go.
I added Rostra universal cruise control to my 2004 4-cylinder 5-speed XE in January works great. It's for us guys with "older" trucks who still have an accelerator pedal.
The kit is very good. The instructions are somewhat sucky (especially on the wiring instructions, how was I supposed to know that the brown wire on the keypad connected to a red wire with a tiny brown stripe and NOT the brown wire from the module?). The Frontier had an unused place for factory cruise control already, and there I used a non-used loop adapter from my similar decade-old cruise control (for my 1988 Mazda truck) to loop over a 5mm stainless steel bolt that I attached there.
I can probably upload pictures within a few weeks if helpful.
For what it's worth I just recently picked up a set of fog lights at Harbor Freight for $14.99 and they fit almost perfectly in the stock holes. Mine had fog lamps at one point but they rusted away and all that was left was the connector which I just spliced into for power. They work on the stock switch too which is pretty cool.
i know the PIAA is a lot more then $15 lights but, the light output of cheaper lights verses higher end lights its surprisingly a lot. even between my PIAA 510's and insanely expensive off road lights there a difference.
Normally I dont buy ebay **** for my cars, but the foglight kit was the exception I only wish the OEM headlight switch with the foglight toggle on it had the same plugs as my XE one.
But Im very happy with the purchase, the bulbs are replaceable too. Cant really go wrong I prefer the OEM look
