Old 05-12-2008, 02:28 PM
mr maraki's Avatar
'fresh air' vent mod?
I've seen references to opening up the vent intake for the outside air setting on the cabin fan. Mine blows hot air from the engine bay, much hotter than the outside air. I've searched around and can't find the how to thread that is supposedly on here, anyone have the link?
2001 Crewcab XEV6 2WD auto
Old 05-12-2008, 06:13 PM
if you find it please do post it because I am interested in this too
soon to come
SAS baby
SAS count down-
36" swampers
front R&P
rear R&P
rear locker
t-case crawler gears
Old 05-12-2008, 10:30 PM
jerryp58's Avatar
I'm a little confused. On my '04, turning the vent selector to the "dash vents only" setting will allow airflow from outside air (fan position doesn't matter).
If you're having hot air come out of the vents, it sounds like the temp selector is not working properly. I also had a vehicle that had a pneumatic valve that allowed (or stopped) the flow of coolant to the heater core. That valve went bad and no matter what the temp selector was set to, it would allow coolant to the HC and I ended up with hot air out of the vents. I took a quick look through my service manual but couldn't find how my coolant flow is controlled; I'll look some more.
Jerry
My Frontier Page
Old 05-12-2008, 11:03 PM
steve0616's Avatar
Is this the mod where you punch out some of the plastic on the cowl?
2004 Electric Blue CC SB LE:
Old 05-13-2008, 01:51 AM
mr maraki's Avatar
Yes
Old 05-13-2008, 02:15 AM
roastbeef's Avatar
i have never heard of such a mod, but make sure the temp. dial is on the 'cold' setting, otherwise it will put hot air in the cab. (just in case you didn't know.)
i always run mine on the 'defroster' setting, and don't notice any hot air coming in from the vents.
Old 05-13-2008, 12:46 PM
mr maraki's Avatar
Found it, looks like it was also a service bulletin for 2000-2001 models so maybe it doesn't affect other years.
Xterra Firma (BoarderPhreak) - custom truck mods
I'll give it a shot and post up if it helps at all.
Old 05-14-2008, 06:34 PM
XE_KING's Avatar
Mine definatly blows warm air! tried it yesterday being as yesterday was the first ok weather day in a while. Thanks for the link!!
-Nick-
F.W.O West Coast Chapter
Old 05-14-2008, 09:50 PM
CRIONCHIP's Avatar
I will do this mod for sure. It gets pretty warm here in FL. Will be good for early spring and late fall.
2004 Frontier Crew Cab 2wd
NISMO CAT BACK
K&N Drop In
Air Box Mod
BFG All Terrain T/A KO 31x10.5x15
FullTilt Tonnou Cover
Old 05-14-2008, 10:14 PM
daves d22u's Avatar
i'll def give it a shot. anythings better than having run the ac.
