if you find it please do post it because I am interested in this too
Ghetto 99 frontier 4x4 v6. daytona black steel wheels, 31" super swampers, t-bar lift, custom cai... three kicker cvr12's , kenwood deck...ghetto... |
If you're having hot air come out of the vents, it sounds like the temp selector is not working properly. I also had a vehicle that had a pneumatic valve that allowed (or stopped) the flow of coolant to the heater core. That valve went bad and no matter what the temp selector was set to, it would allow coolant to the HC and I ended up with hot air out of the vents. I took a quick look through my service manual but couldn't find how my coolant flow is controlled; I'll look some more. |
Is this the mod where you punch out some of the plastic on the cowl?
2004 Electric Blue CC SB LE: Air Box Mod, Alpine Type-S Series Speakers, Autometer Ultra-Lite II Volt Meter, Bazooka Tube Subwoofer, DEPO Taillights, Leer 700 Series Bed Cover, Magnaflow Dual Exhaust, Painted Brake Calipers, Projector Headlights, Pilot Racing Pedals, Pioneer AVH-P6800DVD, Torsion Bar Lift, Weatherflectors, 20% Window Tint, WRP Grounding Kit, etc…
Yes
2001 Crewcab XEV6 2WD auto |
i have never heard of such a mod, but make sure the temp. dial is on the 'cold' setting, otherwise it will put hot air in the cab. (just in case you didn't know.)
i always run mine on the 'defroster' setting, and don't notice any hot air coming in from the vents.
![]() "do you ever feel like you're going to tip?" "yes." |
Found it, looks like it was also a service bulletin for 2000-2001 models so maybe it doesn't affect other years.
Xterra Firma (BoarderPhreak) - custom truck mods I'll give it a shot and post up if it helps at all.
-Nick- 01 XE King Cab, V6 4X4 ,5 Speed, K&N filter w/air box mod, Optima Yellow Top, Hyper White Headlights, 3" Lift, Rancho 5000's Bumper To Bumper. Pioneer premier deck, Focal separates with a Alpine amp, Alpine type R 12" sub with Rockford Fosgate 1000w amp W/ a 1 farad cap. ROCKS!!! |
I will do this mod for sure. It gets pretty warm here in FL. Will be good for early spring and late fall.
2004 Frontier Crew Cab 2wd NISMO CAT BACK K&N Drop In Air Box Mod BFG All Terrain T/A KO 31x10.5x15 FullTilt Tonnou Cover
i'll def give it a shot. anythings better than having run the ac.
2002 CC LB SE SC Nismo cai, gibson exhaust, sirius radio, brush gaurd, 2 pc billet grill, bedlined roof rack, bedlined running bars, blacked out headlights, blacked out fog lights, rear black outs, hyper white bulbs every where, gauge pod w/air fuel ratio & boost gauges, 5% tint all around, hella aux driving lights, WRP grounding kit, led 3rd brk light, modded 4th led strip, loose nut behind the wheel !! ![]() ![]() ![]()
