engine code P0455 - Nissan Frontier Forum
post #1 of 6 (permalink) Old 09-01-2009, 02:34 PM Thread Starter
zerobird's Avatar
engine code P0455
my truck is throwing code P0455: Evaporation Emission Controll Leak.
What the hell does that mean?
O2 sensor?
zerobird is offline
post #2 of 6 (permalink) Old 09-01-2009, 02:45 PM
bungee02's Avatar
Send a message via Yahoo to bungee02
There is a valve in the Evap system that probably has trash in it and will not close fully to hold pressure on the vapor recovery system. It's like if you leave your gas cap off. Have you checked your fuel cap? If it is tight then there is a valve that is leaking by, they should replace it under warranty if you are still under it.
Ford Rangers used to have the same problem. I don't think the valve for Frontys are as expensive, Maybe under $40 from the dealer. I would try to clean it and clear the code, before buying. Or if you have a way to check the pressure, see if it holds.
'01/'09/'13/and now 2016 Nissan Frontier PRO-4X, brand new and still stock,for now...
bungee02 is offline
post #3 of 6 (permalink) Old 09-01-2009, 03:47 PM
Quoted: 63 Post(s)
P0455 Evap gross leak. Can be gas cap, vent control valve, cracked evap canister, and lots of other things. Usually the cap or vent control valve. In the rustbelt, the vent control valves are notorious.
D.J.
2015 Crew cab long bed
1979 Datsun 620
BORNGEARHEAD is offline
post #4 of 6 (permalink) Old 09-01-2009, 04:33 PM
TwoBills's Avatar
The sending unit o ring might be leaking. Look on the driveshaft side of your fuel tank for a gas stain. You'd also smell fumes w/a full tank, on a hot day.
TwoBills is offline
post #5 of 6 (permalink) Old 09-01-2009, 09:16 PM Thread Starter
zerobird's Avatar
So i fixed my problem, man do i feel like a dumbass. I didn't put my gas cap on. I opened the lil door and it was sittin in the lil slots on the door. All can can say is i feel retarded but at least it didn't cost anything to fix. LOL! Thats what happens after working 13 hours at work on sunday, gettin 4 hours of sleep sunday night and wakin up at 530 monday morning to go to school and stoppin for gas on the way. I used a scan tool at school today to check the code. Lota work to find out I didn't put the cap on. Thanks for your help though guys.
zerobird is offline
post #6 of 6 (permalink) Old 09-01-2009, 09:47 PM
shakedownstreet's Avatar
Quoted: 34 Post(s)
The simplest answer is usually the correct answer.
2004 - King Cab - XE - 2.4 Liter - 5 Speed - Super Black - 190,000 Miles
Paddle faster, I hear banjos!
shakedownstreet is offline
