Electrical problems
Ok guys i need some help! I have an 03 v6 2wd, and for the last few days its been acting weird. When the truck is on and i turn on the lights the radio cuts out, some time the truck does not start. I went to autozone they check my batt and alt and the are both good. What else can i do/check before i have to go to the stealership?
TIA Tony |
not starting could be the starter, maybe ignition? distributor? idk
How do your batt cables look? are your grounds all ok? X2 on the IDK
You may want to get a secont opinion on the batt. Also while your there have them scan you for codes...
-Nick- 01 XE King Cab, V6 4X4 ,5 Speed, K&N filter w/air box mod,Clutch switch starter button mod,EGR bed rail caps, Optima Yellow Top, Hyper White Headlights, 2.5" Rancho Lift, Rancho 5000's Bumper To Bumper W/steering stabilizer. Pioneer premier deck, Focal separates with a Alpine amp, Alpine type R 12" sub with Rockford Fosgate 1000w amp W/ a 1 farad cap. ROCKS!!! F.W.O West Coast Chapter http://www.myspace.com/xxxsnowboardbum Proper prior planning prevents piss poor performance! Last edited by XE_KING : 05-13-2008 at 07:21 PM. |
Thanks guys, i think it was a weak ground. I went to look under the hood and moved the ground wire on the batt, seemed a little loose, i tightend it up and no problems yet, so im keeping my fingers crossed hoping that is what it was.
