I would say run the E85 in your 2000 and if it dies then burn it
2003 CREW CAB T-Bar crank with shackles, 2 inch body lift, LEER camper top, American Racing 767 with 31x10.5x15 Remington mud brute, Midland CB Radio with Wilson "Little Wil" Antenna, Jensen CD/DVD touchscreen, Kicker KX 700.1 AMP, 2 8 inch Kicker Solo-Baric L5, Performance Headers, WRP grounding kit, bilstein 5125 Future Mods Add A Leaf, Revolver Shackles Rick http://www.corridorwatch.org/ttc/index.htm
DONT run E85
its very harmful to engines.. even the ones that are sort of designed for it itll cause you to have detonation on newer cars, the computer senses the E85 by way of an out of control idle and adjust the fuel map and timing to compensate for the loss in octane your truck doesnt have this feature... unless it has the E85 stamp.. dont run it also to, that corn garbage clogs injectors and plays hell with cats... by the way, anybody notice how it stays exactly 1 dollar less than gas.. yet theres no rarity for corn hahahahaahahahaha
-Josh- 99 Nissan Frontier XE V6 4X4 3 inch lift and 33s... fully shrocked |
Alcohol will attack some rubber, so different seals & hoses must be used. Last edited by Mike202 : 06-20-2008 at 12:50 AM. |
i dont really like ethanol with the idea that using just straight up corn is hiking up the prices of produce and it takes 2 barrels of oil to make one barrel of ethanol...
but that aside, E85 does burn pretty rough and vehicles rated to run E85 are also rated lower gas mileage figures with that fuel over conventional fuel. Your vehicle wasn't meant to use it, so save yourself the time and money and dont use it. I see no point in continuing to make E85 unless theres a more efficient way to make it without using oil and run more efficiently in cars.
XEs ROCK ![]() cardomain page:http://www.cardomain.com/ride/2425259/1 itsmynissan page: http://itsmynissan.com/beefy242 gamertag: The Real Johnso Myspace:http://www.myspace.com/cutestshitever I have a truck. It gets me from A to B. Why I spend so much money changing it, I will never know. Is there a cure for this disease? I have no idea what I would be using all my money for if there was a cure. ![]() |
E85 is a waste of time and good American resources. If it were not for governmental support, ethanol as a fuel would die. Our political leaders would rather curry favor with corn producing States rather than solve the energy problem the correct way.
It's not "Pork Fat Rules!", it's "Pork Barrel Rules!"
06 Nismo 6M 4X4 Blue |
Is the 25% loss in MPG worth the 25% decrease in price? This is the general percentage. It is true that it is cheaper, but what is the cost per gallon? When you convert it all out, it is usually cheaper to run regular then E85.
lol if you're running e85 at the drags, you're losing.
Ha I wonder what this flood will do to our corny method.... lol I bet e85 costs more than 87 within the month.. ![]()
-Nick- 01 XE King Cab, V6 4X4 ,5 Speed, K&N filter w/air box mod,Clutch switch starter button mod,EGR bed rail caps, Optima Yellow Top, Hyper White Headlights, 2.5" Rancho Lift, Rancho 5000's Bumper To Bumper. Pioneer premier deck, Focal separates with a Alpine amp, Alpine type R 12" sub with Rockford Fosgate 1000w amp W/ a 1 farad cap. ROCKS!!! |
