06-01-2008, 09:51 PM
did the grounding kit today
only really took an hour to do all the wires. i had a 15 min duh period trying to get the bolt out on the ps exshaust manifold. couldnt get a socket on it and a box wrench was just useless at first. go threw the ps wheel well and the bolt is smack right in front of your face and a box wrench works flawlessly. and you kinda need a regular old fashion negitive battery terminal unless you want to tweak you stk one to make the eyelit fit.
it was a very easy install. only one bloody knuckle.
i rate this mod a 2 on a range of 1 to 10 ten being the hardest.
it only took 2 beers and i was done.
havnet noticed much of a diffrence except maybe windows went up a second faster and the start was a cycle or 2 quicker. got to give it a few days for the truck to relearn its self battery was off for an hour.
