Coolant problem?
A few weeks ago I noticed that my engine was starting to overheat so I figured it was the thermostat. I was going to change it but then relized how much of a pain it was, and I don't have to much time/tools as of now. I opened the rad cap and filled it all the way to the top. I then opened the overflow and filled that to the max line. Drove around for a day or two, then looked at the overflow bottle and all the coolant was gone. The only coolant left was about .5in from the bottom. So a good bit of coolant was lost, and this is the second time this has happaned. I'm not sure why this is happening, and when the coolant level goes to only being about .5inch above the bottom of the bottle, it stays there all the time. Any ideas whats going on?
after you top everything off does it still over heat. Does it only over heat at a stand still or going down the road. But my guess is that your rad and over flow was never topped off and when ever thing got to temp it empty it out and you just need to refill it but check your hoses and see if any of them are wet and look for leaks just check and make sure. But I would refill and see if it does it again
2003 CREW CAB T-Bar crank with shackles, 2 inch body lift, LEER camper top, American Racing 767 with 31x10.5x15 BFG A/T KO, Midland CB Radio with Wilson "Little Wil" Antenna, Jensen CD/DVD touchscreen, Kicker KX 700.1 AMP, 2 8 inch Kicker Solo-Baric L5, Performance Headers, WRP grounding kit, bilstein 5125 Future Mods 1994 nissan pathfinder XE 4x4 turning into trail rig http://www.corridorwatch.org/ttc/index.htm
if your coolant was low in the radiator, you might have air in the system and need to purge the cooling system.
additionally, when you top off the resevior and radiator and then get the truck warmed up and a little hot it pushes radiator fluid out of the cooling system into the resevoir....if it was full before...now its over full and will spill some out. then when all cools down and it sucks radiator fluid back into the cooling system its giving a lower reading. mine does this as well. don't worry about the resevoir as much...as long as you are within the high-low marks. good luck!
u might have a leak somewhere. i suggest renting a pressure tester from autozone or pepboys or somewhere. its free, well atleast where i go. check the pressure. if pressure tests fine then i would change the radiator cap. the caps r the most common thing to break before anything else.
good luck |
I'd watch it everyday. missing coolant is not a good thing. check every hose for wetness and leaks. keep the coolant level in the rad full the bottle is not important right now. watch the temp gauge to see if it goes past the h
the reason being is that you are saying tell tail signs of a head gasket leak. have some one give your truck throttle to about 2500 rpm and go smell your exhaust. see if it smells really bad like oil, or if its got a sweet smell like coolant. good luck man when my head gasket went on my fronty i was luckily still under warranty. i am actually starting my gf's civics head gasket tonight that over heated this morning. if you let it go you can ruin the entire engine.
2002 CC LB SE SC Nismo cai, gibson exhaust, sirius radio, brush gaurd, 2 pc billet grill, bedlined roof rack, bedlined running bars, blacked out headlights, blacked out fog lights, rear black outs, hyper white bulbs every where, gauge pod w/air fuel ratio & boost gauges, 5% tint all around, hella aux driving lights, WRP grounding kit, led 3rd brk light, modded 4th led strip, loose nut behind the wheel !! ![]() ![]() ![]()
lol
don't breath in too deep now def check the head, all hoses, and blinker fluid levels, the first two are the most important though
off the topic but subaru had a technical service bulletin in 95 or 96 for 2 table spoons worth of stop leak to fix a head gasket problem they had. and it worked.
get some stop leak!
try it out, if it doesn't work, take it to a mechanic and tell them its broken
keep in mind what the stop leak does. it clogs up stuff, including the leak. so it can potentially hurt ur cituation. it is a band aid fix.
| Thread Tools | |
| Display Modes | |
