CODES CODES CODES! kinda cool
I was looking around online for stuff on our trucks and found these, not sure if they are any help to anyone at all but I thought I'd post. These are the codes for the 3.3 and 2.4 frontier and exterra Nissan Frontier Extera Truck 3.3L OBDII Trouble Codes DTC Troubleshooting FRONTIER & XTERRA 3.3L P0000 No Self Diagnostic Failure Indicated P0100 MAF Sensor P0105 Absolute Pressure Sensor P0110 IAT Sensor P0115 ECT Sensor P0120 TP Sensor P0125 ECT Sensor P0130–P0134 Front HO2S RH Bank P0135 Front HO2S Heater RH Bank P0136–P0140 Rear HO2S RH Bank P0141 Rear HO2S Heater RH Bank P0150–P0154 Front HO2S LH Bank P0155 Front HO2S Heater LH Bank P0157–P0161 Rear HO2S LH Bank P0171 Fuel Injection System Lean RH Bank P0172 Fuel Injection System Rich RH Bank P0174 Fuel Injection System Lean LH Bank P0175 Fuel Injection System Rich LH Bank P0180 Tank Fuel Temperature Sensor P0217 Engine Over Temp P0300 Multiple Cylinder Misfire P0301–P0306 Misfire Cylinders 1–6 P0325 Knock Sensor P0335 CKP Sensor P0340 CMP Sensor P0400 EGR Function P0402 EGRC-BPT Valve Function P0420 TWC Function P0430 TWC Function P0440 EVAP System Small Leak P0443 EVAP Canister Purge Control Valve & Solenoid Valve P0446 EVAP Canister Vent Control P0450 EVAP System Pressure Sensor P0500 VSS P0505 IAC-AAC Valve P0510 CTP Switch P0600 A/T Control & Communication Line P0705 Park Neutral Position Switch/Circuit P0710 ATF Temp Sensor/Circuit P0720 Vehicle Speed Sensor/Circuit P0725 Engine Speed Signal P0731 A/T 1ST Gear Function P0732 A/T 2ND Gear Function P0733 A/T 3RD Gear Function P0734 A/T 4TH Gear Function P0740 TCC Solenoid/Circuit P0744 A/T TCC Switch/Valve Function P0745 Low Pressure Solenoid/Circuit P0750 Shift Solenoid A/Circuit P0755 Shift Solenoid B/Circuit P1105 MAP/BARO Switch Solenoid Valve P1148 Closed Loop B1 P1168 Closed Loop B2 P1320 Ignition Signal P1336 CKP Sensor P1400 EGR Valve & EVAP Canister Purge Control Solenoid Valve P1401 EGR Temperature Sensor P1402 EGR System P1440 EVAP System Small Leak P1444 Purge Volume Control Valve P1446 EVAP Canister Vent Control Valve P1447 EVAP System Purge Flow Monitoring P1448 Vacuum Cut Valve P1490 Vacuum Cut Valve Bypass Valve P1491 Vacuum Cut Valve Bypass Valve P1605 A/T Diagnosis Communication Line P1705 Throttle Position Sensor/Circuit A/T P1706 PNP Switch/Circuit P1760 Over/Run Clutch Solenoid/Circuit Nissan Frontier Extera 2.4L OBDII Trouble Codes DTC Troubleshooting List Guide FRONTIER & XTERRA 2.4L P0000 No Self Diagnostic Failure Indicated P0100 MAF Sensor P0105 Absolute Pressure Sensor P0110 IAT Sensor P0115 ECT Sensor P0120 TP Sensor P0125 ECT Sensor P0130–P0134 Front HO2S P0135 Front HO2S Heater P0137–P0140 Rear HO2S P0141 Rear HO2S Heater P0171 Fuel Injection System Lean P0172 Fuel Injection System Rich P0180 Tank Fuel Temperature Sensor P0300 Multiple Cylinder Misfire P0301–P0304 Misfire, Cylinders 1–4 P0325 Knock Sensor P0335 CKP Sensor P0340 CMP Sensor, Detectable & Non-Detectable Circuit P0400 EGR Function P0402 EGRC-BPT Valve P0420 TWC Function P0440 EVAP System Small Leak P0443 EVAP Canister Purge Volume Control Solenoid Valve P0446 EVAP Canister Vent Control Valve Circuit P0450 EVAP Control System Pressure Sensor P0500 VSS P0505 IAC-AAC Valve P0510 CTP P0605 ECM/ECCS Module P1105 MAP/BARO Switch Solenoid Valve P1148 Closed Loop Control P1320 Ignition Signal P1336 CKP P1400 EGR & Canister Control Solenoid Valve P1401 EGR Temperature Sensor P1402 EGR System P1440 EVAP System Small Leak P1444 Purge Volume Control Valve P1446 Vacuum Cut Valve P1447 EVAP Purge Flow Monitor P1448 Vacuum Cut Valve P1490 Vacuum Cut/Bypass Valve P1491 Vacuum Cut Valve Bypass Valve P1706 Park/Neutral Position Switch P1775 TCC Solenoid Valve Circuit P1776 TCC Clutch Solenoid Valve
So this may be a dumb question but Ill ask it anyway.. If my truck was throwing a code would I know it? I mean would something light up on the dash? Or is this something I would need to hook up to a code reader to find out?
-Nick- 01 XE King Cab, V6 4X4 ,5 Speed, K&N filter w/air box mod,Clutch switch starter button mod,EGR bed rail caps, Optima Yellow Top, Hyper White Headlights, 2.5" Rancho Lift, Rancho 5000's Bumper To Bumper. Pioneer premier deck, Focal separates with a Alpine amp, Alpine type R 12" sub with Rockford Fosgate 1000w amp W/ a 1 farad cap. ROCKS!!! |
Some will set off the dash light some wont. It all depends on what it is.
Goes both ways... some codes set off a SES light; or other warning lights on the dash; some don't (like the knock sensor in the first gens-- you might not know it's bad til you check and it throws a code.)
GOOD info thebrandon..... sticky for first gens, anyone??
'03 Silver Ice S/C Desert Runner 4x2 5-spd manual On since I've been on CF: Tow Hitch Next Mod: 2.4 SC Pulley!!! Glow Shift boost gauge; and maybe some Yoko Geolander A/T S's... with some spacers That was fun. Who wants to do it again? |
Sticky PLAESE! This is going to be a good source of info for myself as well as many others I believe!
Only emission related codes light the Service Engine Soon light.
2003 XE V6 Frontier: [Current Mods: Nismo Intake+Exhaust+Rims+Shocks, 32" Pirelli Scorpion ATRs, 2" Lift, Manik Brushguard, 3x5 KC HiLites, WT Window Deflectors, 2 Rockford Fosgate P1 Subs + Kenwood Amp] |
ha I guess some people did find this useful
I'll make a post of the codes in the sticky on the top of the page
good find, my service engine light came on all the freakin time in my '01, due to a rusted cat converter, wanted to just cut the dang thing off but had to have my brother in law code it as good often.
08 SE CC 4x2, Avalanche White WANT CHROME, LOTS AND LOTS OF IT! |
my light pops up a little more often than I would like. I finally got it to go out today by replacing that purge valve solenoid, at least I hope it stays off
Went to Baxters and had them run the tester for me... NO CODES!!!
