Old 06-09-2008, 10:22 AM
nismofan01's Avatar
cluster probs?? 1st gen
so i took my truck off roading a few days ago, well i made the mistake of going through a seriuos puddle, more like a lake actually, it went up to my hood roughly, noprobs at time then i noticed my cluster lights wont work and my warm/cold and heating and air lights do not work now, anyone every have this? checked fuses all good
01 SE CC 2WD auto
L.E.D third brake light
Jensen flipout
10k H.I.D headlights
3K H.I.D fogs
K&N cold air
Gibson cat-back
z31parts-Intake manifold plenum spacer
170' thermostat
Definity 31x10.5 R15's
Future plans...
Navara hood
Calmini T-Bars
Calmini Add a-leaf for 3inch lift
Calmini front/rear bumper
ARB air locker
Old 06-12-2008, 12:20 PM
Did you check the fuses in the box with the relays?
Old 06-12-2008, 12:35 PM
TxFront's Avatar
check the fuse's under the hood by the battier I crossed a wire one time and my dash lights would not work and it end up being a blown fuse under there
2003 CREW CAB
Future Mods
Old 06-13-2008, 02:53 AM
nismofan01's Avatar
i checked ever fuse high and dry lol, i have no idea what it could be, i figured it would deff be a fuse under hood considering that all got wet when i went through puddle, my 1-4 lights dont work aswell as climate control lights
01 SE CC 2WD auto
Jensen flipout
3K H.I.D fogs
K&N cold air
Gibson cat-back
170' thermostat
Future plans...
Navara hood
Calmini T-Bars
ARB air locker
Old 06-13-2008, 03:54 PM
Suggestion: pull each of the fuses you suspect getting wet and clean the posts? maybe some mud got in there and is keeping things from making good contact.
Old 06-13-2008, 08:06 PM
nismofan01's Avatar
that is tru, never thought of that, im gonna test light them aswell and see what i find
01 SE CC 2WD auto
Jensen flipout
3K H.I.D fogs
K&N cold air
Gibson cat-back
170' thermostat
Future plans...
Navara hood
Calmini T-Bars
ARB air locker
Old 06-16-2008, 03:48 AM
that happened to me one time, all my lights were doing all sorts of funky things, it was my alternator though, not a fuse
our trucks have the alternator in a very horrible spot for water crossings/mud/dirt
at least the v6 models do, I'm not sure which you have
soon to come
SAS baby
SAS count down-
36" swampers
front R&P
rear R&P
rear locker
t-case crawler gears
Old 06-16-2008, 11:17 AM
adrenaline503's Avatar
Make sure you use a multimeter to check your fuses, instead of the typical visual inspection. Or just switch it out with a new one, when it comes to troubleshooting a water intrusion issue it helps to check everything correctly the first time.
2004 Nissan Frontier Crew Cab
Ute Ltd Flatbed
