#1
Dec 9, 2016
I can check/set the timing on a 2002 VG33 using a standard inductive timing light, correct? Don't need any weird tool right?
#2
Dec 10, 2016
Yeah all you need is a regular timing light
Sent from my XT1080 using Tapatalk
#3
Dec 10, 2016
I painted the mark white when I timed the distributor on my daughter's '98 Pathfinder with that engine (I had replaced the distributor for her). Regular timing light, about 30 years old.
#4
Jan 17, 2017
Pickoff?
Do you use the number 1 spark plug wire for the inductive pickoff for the timing light?
#5
Jan 18, 2017
Yes and make sure the arrow on the pickup clamp is facing the plug if yours has an arrow
0
