your getting codes in in both banks so thats a sign something in the upper half of emmisions is going bad. possible mass air leak(vac hose leak) or yes even a mass air flow sensor. they do go bad. you have and intake on your truck? wet or dry filter? when you clean it last?
but its saying tell tail signs of leaking intake gaskets. running rich. rough idle poor gas mileage. gaskets maybe $30 and i would replace plugs while your there since its been idle rough they could be carboned up.
2002 CC LB SE SC Nismo cai, gibson exhaust, sirius radio, brush gaurd, 2 pc billet grill, bedlined roof rack, bedlined running bars, blacked out headlights, blacked out fog lights, rear black outs, hyper white bulbs every where, gauge pod w/air fuel ratio & boost gauges, 5% tint all around, hella aux driving lights, WRP grounding kit, led 3rd brk light, modded 4th led strip, loose nut behind the wheel !! ![]() ![]() ![]()
get some starter fluid.. get the truck at idle, spray it all along the intake tube up the manifold and around all hoses and gaskets. If your idle changes at any point you have a leak. Dont give up on it yet! lol
-Nick- 01 XE King Cab, V6 4X4 ,5 Speed, K&N filter w/air box mod,Clutch switch starter button mod,EGR bed rail caps, Optima Yellow Top, Hyper White Headlights, 2.5" Rancho Lift, Rancho 5000's Bumper To Bumper. Pioneer premier deck, Focal separates with a Alpine amp, Alpine type R 12" sub with Rockford Fosgate 1000w amp W/ a 1 farad cap. ROCKS!!! |
Daves, if KSDtoday fixes a "leak" will the p0430 code be resolved orr will he have to replace the cat?
jm |
fix any of the leaks clear the codes and the efficency code should stay away. unless its really clogged.
