Old 11-18-2007, 12:32 AM
catalytic converter heat sheilds removeal
Anyone have any problems after taking off their shields?
Just recently I was getting a terrible rattling sound from the exhaust I checked under it today and found the catalytic converter heat shield so loose that half of it had rust through and you could move it back and forth. I removed both pieces. I see the riders side does not look any better and probably will have to remove that one as well sometime soon.
Old 11-18-2007, 08:53 AM
Zero Six LE's Avatar
You might want to reconsider removing the shields. The heat could pose problems for the floorboard and the carpet above the cats.
02 Maxima SE Tungsten Blue
Old 11-18-2007, 09:51 AM
FewMo's Avatar
Send a message via AIM to FewMo
Yeah man put those back on,I had taken them off on my last car because the custom exhaust i put on it, the heat shields didnt fit, and after a bit it burnt my carpet
Old 11-18-2007, 10:07 AM
Ok looks like I can buy a set for the truck.
There is a set of shields that are around the converter and then there is another heat sheild on the underside of the body too. So hopefully it will not burn through before I get new sheilds.
http://www.courtesyparts.com/betasit...2154_2156.html
They are cheap so I will just a set.
Old 11-18-2007, 10:17 AM
I thought you were talking about the heat shields above the cats. The lower shield is also important to keep from starting fires on dry grassy areas you might park on.
Old 11-18-2007, 10:24 AM
Yeh, I was talking about the heat shield around the cat... Sorry for the confusion. I usually don't park in the grass but I will change get it updated so just in case. I was surprised those things are a good 10 lbs.
