A/C turns off when fan blower set to '4' - Nissan Frontier Forum
post #1 of 11 (permalink) Old 04-19-2017, 01:39 PM Thread Starter
Question A/C turns off when fan blower set to '4'
Hi all,
I've noticed an ongoing issue with my truck (99 2wd 4cyl 5spd). The fan blower works in all settings (1-4), and A/C works in fan blower settings 1-3, but when I have A/C on and switch to fan blower setting 4, the A/C compressor kicks off. Fan still works as expected.
The odd part is that sometimes A/C does work on fan setting 4, but A/C will kick off shortly thereafter.
I've searched the forums and found similar issues described with the fix being to replace the blower motor resistor pack, but the exact symptoms do not match what I'm seeing. In other threads, the fan blower works only in setting 4, and the issues seem unrelated to A/C.
Any ideas?
madslackin is offline
post #2 of 11 (permalink) Old 04-19-2017, 06:59 PM
Cusser's Avatar
Quoted: 204 Post(s)
The symptoms depend upon which part of the resistor pack is bad. Sounds like you have a break in one of the coils, and sometimes that vibrates into place so it works for a bit.
Your alternative is to use speeds 1-3 until something else breaks. By the way, the slower the blower speed, the colder the air will be (longer residence time to exchange heat in the evaporator). I'm in the Arizona desert, and typically use blower speeds 2 and 3 on my 1998 and 2004 Frontiers.
'98 2WD, 4-cylinder, 5-speed, white regular cab, purchased in 2004 with 100K on it for the kids to drive, now it's back with us, 214K. 2004 King Cab 2WD, 4-cylinder, 5-speed, electric blue purchased in Dec. 2011 at 89K. Also 1988 Mazda B2200 Cab Plus truck (since 1994, 212K), 2WD, 4-cylinder, 5-speed, great truck. And 1971 VW Convertible (mine since 1976) and 1970 VW (mine since 1972).
Cusser is offline
post #3 of 11 (permalink) Old 04-20-2017, 04:14 AM
Quoted: 90 Post(s)
Blower motor resistor, cheap and easy fix
Edit : re read your symptoms, that's unique, never had a problem like that before but if it was mine I'd throw a resistor at it
Sent from my XT1080 using Tapatalk
kevinjohnson3216 is offline
post #4 of 11 (permalink) Old 04-20-2017, 12:54 PM Thread Starter
Thanks for the input, guys!
post #5 of 11 (permalink) Old 04-21-2017, 07:31 AM
shakedownstreet's Avatar
Quoted: 34 Post(s)
try replacing your hifi head unit
2004 - King Cab - XE - 2.4 Liter - 5 Speed - Super Black - 190,000 Miles
Paddle faster, I hear banjos!
shakedownstreet is offline
post #6 of 11 (permalink) Old 04-21-2017, 09:26 AM
geekmyride's Avatar
Quoted: 71 Post(s)
Most blower motor resistor problems will result in one or more of the lower speeds not working. Usually the highest setting bypasses the resistor network completely. Is it the blower motor or the A/C compressor that stops running at high speed?
Let the mods begin! The project list can be found in the Geek My Ride Garage!
Previously owned a 1985 Nissan King Cab 4wd and a 1980 Datsun 2wd Pickup.
geekmyride is offline
post #7 of 11 (permalink) Old 04-21-2017, 09:41 AM
Cusser's Avatar
Quoted: 204 Post(s)
Read.
Cusser is offline
The Following User Says Thank You to Cusser For This Useful Post:
shakedownstreet (04-21-2017)
post #8 of 11 (permalink) Old 04-21-2017, 10:49 AM
Quoted: 34 Post(s)
Originally Posted by Cusser View Post
Read...
...ing is fundamental
post #9 of 11 (permalink) Old 04-21-2017, 12:36 PM
geekmyride's Avatar
Quoted: 71 Post(s)
Thanks for caring enough to tell me to read the OP... I actually did read it. My response was to explain why the blower resistor network would likely not be the cause of the problem, even though almost everyone posting before me is sending him/her to buy a new resistor network.
post #10 of 11 (permalink) Old 04-22-2017, 11:17 AM
Quoted: 31 Post(s)
Thermal Contol Amps are notorious for intermittently failing and shutting down the compressor.
2000 2WD 2.4 five speed KC
Roader is offline
The Following User Says Thank You to Roader For This Useful Post:
madslackin (04-25-2017)
