I'm in a similar boat as you... I don't tow much, only for now. I'm a 4WD V-6, first gen, and I need new pads and rotors as well.
From what I've seen so far, there aren't any slotted or drilled rotors for the first gens... or atleast I haven't come across any yet. Maybe I skipped over it accidentally.
Tools required:
Now the first time I did brakes on a nissan was my brothers '98 pathfinder. They might be slightly different from the frontier, but they aren't far off if so. There is a retaining ring that will need to be removed, and some phillips screws that hold a spanner nut in place. You might want to make sure your socket set is heavy duty cause some of the bolts were pretty tough to remove on his pathfinder. I'm assuming they will be tough on the truck as well. I think there is a write up for removing all the stuff, try searching for it, and post up if you find it. Rotors aren't as easy on the nissan as they were on my old ford ranger.
Some people pack new grease in their wheel bearings when they're removing stuff for rotors. There is a write up on the forum somewhere you might want to look into. I'm probably gonna do it as well when I replace all my stuff.
Hope this helps.
