Old 07-17-2007, 02:48 AM
WhoAmI351's Avatar
Send a message via AIM to WhoAmI351
Blacked out headlights
has anybody done this on a first gen yet?
Old 07-17-2007, 02:51 PM
dcobb's Avatar
I think it's kind of frowned upon. It's definitely illegal and will dim your headlight vision. I believe most (such as myself) have gone with aftermarket lights as the alternative.
Blacking out the outside is easiest but will wear after time. To do them on the inside supposedly requires separating the two sections which means you'll need to heat up the lights to break down the glue bonding them together, and then reapply once done with the blackout. If you do take this route, I'd recommend using Night shade and then a protectant over that, but again it's not the route I would take.
Now Steve had a set of blacked out lights that were similar to OEM ones, just black instead of Chrome, but I believe they no longer manufacture them. Steve?
Old 07-17-2007, 04:10 PM
WhoAmI351's Avatar
thanks for the info. but since you bring it up, how do you like the halos? is light output and build quality pretty well?
Old 07-17-2007, 04:23 PM
daves d22u's Avatar
I Got The Black Ones. They Dont Make This Kind Anymore They Now Have A Yellow Reflector
Old 07-17-2007, 04:51 PM
FindingNismo's Avatar
black them out your self and save an *** load of cash, its not hard to pull your lamps off, pop them in teh oven for a couple min and pull them appart, paint the chrome, just mask off the reflective chrome that the head light bulb uses and them put them back together. looks just as good as anything else and its pretty cheap. can of spray paint and maybe a tube of black silicone to seal it back up properly
2000 SE CC
turbodub's Avatar
im starting at looking at options too now, one of my lenses is turning yellow.
I like the lights that dcobb has on his rig. Hell his whole rig is just awesome!!
Old 07-17-2007, 05:03 PM
isx_frontier's Avatar
go ebay.. cheap!
nismo bilstein spec shocks, NGK iridium sparkplugs and NGK wires, HID kit, k&n intake, flowmaster exhaust, JBA exhaust tip, westin pushbar with HELLA 500 daylighter, wade vent visor stock s/c
Old 07-17-2007, 05:10 PM
WhoAmI351's Avatar
dave? those lights dont look too bad, kinda give me an idea of how it would look. but do you have any pics of the lights without the gaurd on the front?
Old 07-17-2007, 06:20 PM
Icarus03's Avatar
They still have the black ones with the clear reflector.
On ebay, they have the ugly/cheap/ricer looking projector w/ angel eye headlights.
As far as OEM style, they have an all chrome pair (like stock only with a clear reflector and clear turn signal filter instead of amber), an all black pair like dave's (black housing with clear reflector and clear light filters), and they make these.... which is what I want.
I saw these a couple times only on ebay then just went to the store's website and found them.
These are a grey painted housing with the clear reflector and the OEM style amber filter for the turn signal.
www.x3racing.com is the site that sells these. Good luck.
Old 07-17-2007, 06:30 PM
GarettCarpenter's Avatar
I believe that AVS makes blackout head light covers still, i had them on my 01 XE, looked great. I think thay actually called them smoke but they were dark as sh**
