Old 08-28-2007, 09:26 AM
NeonspeedRT's Avatar
Biggest tires on a Desert Runner?
I have an 04 2wd king cab Desert Runner. It's currently stock height. I've been told I can put 31x10.50's on there with no lift. If I do the shackles in the back and crank the torsion bars about an inch do you think I can put alittle bigger tire on there?
2004 Frontier Desert Runner
1997 CBR900RR
2005 Yamaha R1
MSF Rider Coach
http://www.ammotorcyclesafety.com
Old 08-28-2007, 10:06 AM
turbodub's Avatar
i have a 03 with 285 60 18 on it, i had to remove the front mudflaps and trim out some guts. I dont think i would go any bigger than that, even with an inch of lift, but thats just me.
Old 08-28-2007, 08:33 PM
rocknronnie's Avatar
you still want to use your suspentioin right? Its not always about the biggest tire! but how you are going to use your truck and what tire will work with the suspention.
2006 SE Crew Cab. 4 inch CST spindle, 3 inch Calmini Coil Spacer, TC Upper Control Arms, Stainless Break Lines, PRG Shackles, 1.5 inch block, Billet Grill, Billet Antena, Nismo Headers, Custom Flowmaster Exhuast, K&N Intake, Pioneer 5700 touch screen DVD player, Pioneer Speakers.
Old 08-29-2007, 05:39 AM
dcobb's Avatar
I think 31's are about the most your going to get with a simple lift, possibly 32. You'll probably have to loose your front mud flaps as well
Old 08-29-2007, 08:55 AM
houdini's Avatar
with shackles and a tbar lift i think 32x10.50 would be the biggest.
http://www.noas4x4club.com/
http://www.encxc.org
Old 08-29-2007, 04:11 PM
adorsey's Avatar
I'm going to do shackles and t-bar and i'm considering going with 31" BFG A/T just to be safe and 32" are a lot more per tire than 31"s and right now i'm running 235s so its going to be a massive upgrade.
2000 KC Desert Runner V6, AAL, Calmini Shackles, Calmini UCA's, Rancho 5000s all around, Bilstein Steering Stabilizer, AC idler arm brace, 31" BFG A/T, K&N CAI,
Flowmaster 50 SUV,WRP Grounding Kit, NGK Plugs and Wires, Silverstars, AVS Ventshades, 20% tint, Headunit, 600w amp, 12" sub, Door Speakers
Old 08-29-2007, 04:30 PM
pbh114's Avatar
I'm running 32x11.50 BFG AT's with a three inch body lift and an add-a-leaf in the rear with no problems. With shackles and a t-bar crank I'm not sure I would go that big.
'00 XE CC V6, 3" body lift, Calmini UCA's, add-a-leaf in the rear, bronze Nismo wheels, 285/75R16 Nitto Teragrapplers, AEM Brute Force CAI, Nismo exhaust, ultra low-pro upper UCA bump stops, Bilstein steering stabilizer, AC idler arm brace, AVS Ventshades and Bugflector, Viair 350c air system with 150dB Siege Engineering Hammer 3 Air horn
Old 08-29-2007, 06:52 PM
adorsey's Avatar
Well I have the front mud flap off right now and the local tire guy said they would fit find with that much lift but i'm also a little worried. Did you order yours online or from a local tire guy?
Old 08-29-2007, 07:37 PM
pbh114's Avatar
I got mine from my local shop for about 150 per tire installed.
Old 08-29-2007, 08:14 PM
adorsey's Avatar
Thats pretty good. The 31" are 122 or so from a online place so i'm gonna go down there tomorrow and just look around.
