bad gas milage - Nissan Frontier / Navara Forum
Old 11-17-2012, 10:49 PM
bad gas milage
hey guys i have a 2002 nissan frontier xe v6 crew cab, and as of now i have a the truck lifted 3 inches body lift and a additional 2 inch lift with 15x10 wheels with 32in tires. as of now im average about 50 miles on a quarter tank, is there something wrong with the truck or is it becuase of the lift and wheels? i have had the spark plugs change all the fluids flushed and swapped with new fluids a couple months ago. everybodys been telling me theres something wrong but im not sure. is there anything that i can do to raise the mpg such as performance mod or anything? here is my truck now
Old 11-17-2012, 11:20 PM
dubie2003's Avatar
What is the true mpg? ie. miles driven divided by the amount of gallons to bring it back up?
The lift, wheels, tires, etc.. are not helping. On top of that, the climate and ethanol gas......
How is your knock sensor? How are your driving habits?
07 SE CC Auto
Old 11-18-2012, 01:24 AM
shakedownstreet's Avatar
my fuel gage goes down about a quarter after 50 miles. i average around 23 mpg overall (4cyl)
2004 - King Cab - XE - 2.4 Liter - 5 Speed - Super Black
Paddle faster, I hear banjos!
Old 11-18-2012, 07:32 AM
D22 D22 is offline
When talking MPG, quarter tanks and tank measures mean nothing.
eg.
Car A gets 100 mpg but has a 1 gallon tank
Car B gets 50 mpg but has a 10 gallon tank
Car A would run out of fuel before car B despite car A getting better mileage.
All gas gauges act differently. Even in the same car there are variations (age and whatnot) so your quarter tank wont be the same as someone elses. Also looking at a guage you can only estimate. A minute difference on the guage can be a whole 1/4 gallon of fuel in the tank, you just lost 10 miles.
- Do you drive around town a lot? 0 mph and engine running is bad for mileage. Low speed low gear also reduces mileage.
- 32 inch tires and you loose some gearing advantage (more throttle to keep speed)
- Stoplight grand prix? Bad mileage
- Tow a lot? Bad mileage
- Your foot heavy as mine? Bad mileage
It all adds up and the majority of it would be down to driving habits. Make sure your sparks are gaped properly too.
The way to calculate what you are getting is to:
1 - Fill tank
2 - Note odometer reading
3 - Drive regularly
4 - Fill tank when necessary
5 - Note odometer reading and fuel pumped
6 - Take the distance and divide by fuel pumped (eg. 250 miles/10 gallons = 25 mpg)
7 - Observe result
For accuracy do that several times, will take a while.
2007, D22, Double cab, 4WD, KA24DE, 5 speed manual, work truck (worked hard).
Old 11-18-2012, 08:09 AM
nissanaddicted's Avatar
if you are still getting 23 mpg with a lift and big tires on a 4cyl. I'd say its still doing pretty good. I imagine that 2.4 is working pretty hard to turn those big tires.
2011 SV Crew Cab long bed 4x4 Purchased 4/13/11
Mods
Curt hitch, Scanguage II, +2 degree Timing advance,450W inverter
30% tint on front windows, Diamondplate aluminum chest toolbox and wheelwell box,
Touch screen Hu with rear view camera and Bt, DeeZee rubber bed mat, Angel eye foglights,
TruXedo trucksport tonno, Hypertech Max Energy, Lift. Adf 2" spacers up front. Prg 1.5's in the rear
Old 11-18-2012, 02:02 PM
jerryp58's Avatar
1 - Fill tank
3 - Drive regularly
7 - Observe result
Unless you've done something to adjust your speedometer/odometer, I'd add one more step.
6.1 - multiply mpg in 6 by 1.15
If your stock tires were like mine, 225/70-15, your miles travelled may actually be 15% more than what your odometer is showing because of the increased tire diameter (and therefore, fewer revolutions per mile). I believe the ratio, new-tire-diameter/old-tire-diameter should be the difference.
I would think the larger, heavier tire/wheel combination would decrease mpg, but unless you calculate it like D22 stated and make any necessary adjustment for actual miles travelled, you won't really have a good idea of what your truck is doing.
Jerry
2004 Frontier, King Cab, XE, 4-cyl, 5-spd, 4x1
The Following User Says Thank You to jerryp58 For This Useful Post:
Escapehatch (11-18-2012)
Old 11-18-2012, 03:02 PM
zoomzoom's Avatar
the shape of a gas tank is asymmetrical. 1/4 tank, 1/2 tank, 3/4 tank means nothing
Old 11-18-2012, 04:42 PM
Gregg the G's Avatar
My 03 CC lwb 4x4 gets an avg. of 14.9 for this year best being 16.8---worst is 13.8 mpg
winter/summer fuels do make a diffenence as does YOUR lift (more air goin under the truck) and the size and weight of your tires.
Old 11-18-2012, 08:24 PM
Escapehatch's Avatar
This actually never crossed my mind before. I went ahead and calculated the difference between my stock tires and the 31's I have, turns out I should be multiplying my mileage by a little less than 1.05. If this is accurate, I'm actually getting close to what I should be getting. Although I'm a little curious, how big are your current tires since you're multiplying by a whopping 1.15?
2002 XE CC LB 4x4
1984 720 KC 4x4
Old 11-18-2012, 08:34 PM
05Fronty4x's Avatar
1.15 is the ratio between the size he mentioned being stock (225/70r15) and 32" tires that tri856 has. It's actually closer to 1.17, but who's counting.
2012 Pro-4x CC
