I would say go ahead and put a new pump in it. Then you will probably need 3rd gear clutch assy. and the third gear band. Your servo sounds like it's working but something is slipping inside of it. just a new pump would probably make a big difference due to mileage. And then of course a gasket and seal kit.
Future mods: Get axle mounted and ready for fall noas ure run!
