Check in the new HOW To section of my write up.
where exactly is the fuel filter on these? i havnt looked yet
-03 Desert Runner (v6 2wd) Airbox mod, K&N air filter, Flowmaster 40series w/2.25"out the back, pioneer Avic-D3- |
i did the plug and it works pretty good. i have the intake,exhaust but need to get some better sparks and am going to clean the MAF. thanks titanws6 for the idea. got mine at homedepot. $3.00
I wouldn't recommend any wet type air filter for our trucks our any vehicle with a maf for that matter
what do you guys use to clean the MAF?
You can clean the MAF w/ some MAF cleaner from your local autoparts store. When removing the airbox lid, disconnect the wiring harness to the MAF, do not try to remove the MAF from the lid itself, just stick the spray hose that comes w/ the MAF cleaner down there and coat it pretty good, the stuff dries instantly, I doused mine pretty good. No problem Redbeard82, glad I can help. Yeah I stuck w/ a paperfilter too, they pretty much catch just as much. Hey Demondrive, did you do the T-Bar adjustment yet to help level out the front of the truck? Just another free mod, and is pretty easy to do. There is also a write-up on that as well.
2000 FRONTIER DESERT RUNNER Last edited by Titanws6 : 05-10-2008 at 11:45 AM. |
I think it is a 1.25" plug for the smaller one... I left the spongy stuff in there.. Didnt know If it would be good or bad to remove.. Figured it would soak up any water that got in there.. Who thinks I should take it out? I left the front tube going into the fender so I didnt need to move the air temp sensor but trimmed the end of the tube. I also left the side tube that went into the fender resinator.. But I removed the resonator its self.. 30 min job.. SIDE NOTE: Carefull removing the snaps under the fender.. they tend to break.. Good nws is you can get them from your local auto parts shop..
Use CRC MAF sensor cleaner.. get it at your local shop.. unscrew the sensor at the top and carfully remove it from the tube.. spray it off from all directions, Let it dry(10 sec) re-install. wipe the screen off if it is dirty..Also If you use a oiled filter, It is good to clean the mafabout a day after filter cleaning and oiling.. Sometimes the oil can suck into the MAF and cause a rough Idle..
-Nick- 01 XE King Cab, V6 4X4 ,5 Speed, K&N filter w/air box mod,Clutch switch starter button mod,EGR bed rail caps, Optima Yellow Top, Hyper White Headlights, 2.5" Rancho Lift, Rancho 5000's Bumper To Bumper. Pioneer premier deck, Focal separates with a Alpine amp, Alpine type R 12" sub with Rockford Fosgate 1000w amp W/ a 1 farad cap. ROCKS!!! F.W.O West Coast Chapter Last edited by XE_KING : 05-10-2008 at 03:10 PM. |
