3-1/2 quarts sure doesn't seem like much - Page 3 - Nissan Frontier Forum
post #21 of 39 (permalink) Old 11-05-2012, 05:50 PM
Gregg the G's Avatar
The extra oil would lower motor temps too. (heavy towing , off roading)
A larger oil filter could add some capacity.
Gregg the G is offline
post #22 of 39 (permalink) Old 11-08-2012, 03:49 AM
Nyjd516's Avatar
Quoted: 3 Post(s)
@handb94, where did you get the larger oil pan from? And I've seen at Walmart the little computer says there's two oil filters, ones for clearance issues. So do they make a longer one?
Nyjd516 is offline
post #23 of 39 (permalink) Old 11-08-2012, 09:58 AM
mag2367's Avatar
I read a thread about somebody nodding their pan to hold more oil, while I agree it doesn't improve lubrication over the stock setup, however with most things in life; the solution to pollution is dilution. Every time I call for 3.5 quarts at my shop the parts guys look over at my truck and also ask me to repeat how much oil to send Haha.
mag2367 is offline
post #24 of 39 (permalink) Old 11-08-2012, 12:19 PM
Hertz's Avatar
Quoted: 13 Post(s)
Here's the thread:
My '04 Build/Messin' with it Thread
You can't make it bigger if you're 4wd. There's a reason its so small.
Hertz is offline
post #25 of 39 (permalink) Old 11-08-2012, 12:29 PM
handb94's Avatar
Quoted: 31 Post(s)
Send a message via Skype™ to handb94
Another member on here modified his hand and I bought it off of him. Is correct if you have 4 wheel drive it won't work as the extension will hit the front diff. Dilution is correct. It is easier to keep a 150 gallon fish tank than a 10 gallon fish tank.
The Dark Trooper.My Build Thread
Next project: Replace piston rings
Trust me, I fix cars for a living. ASE Master Tech. Volvo Master Tech.
What I built my bumper for. http://www.youtube.com/watch?v=06d8AyFG9Ts
handb94 is offline
post #26 of 39 (permalink) Old 11-08-2012, 01:03 PM
speedfoos's Avatar
Quoted: 12 Post(s)
Glad the pan is still working out for you.
speedfoos is offline
post #27 of 39 (permalink) Old 11-08-2012, 02:27 PM
handb94's Avatar
Quoted: 31 Post(s)
It is thank you. If I ever get around to converting to 4wd I will pass it on to another member.
handb94 is offline
post #28 of 39 (permalink) Old 11-08-2012, 03:26 PM
mag2367's Avatar
If you do swap to 4x4, I would totally buy that pan from you...must....have...
mag2367 is offline
post #29 of 39 (permalink) Old 11-08-2012, 05:54 PM
handb94's Avatar
Quoted: 31 Post(s)
Haha. I will definitely let you know.
handb94 is offline
The Following User Says Thank You to handb94 For This Useful Post:
mag2367 (11-08-2012)
post #30 of 39 (permalink) Old 11-08-2012, 10:32 PM
could add a bypass oil filter. Increases capacity and keeps the oil cleaner. Did this on mine, also relocated the oil filter so both the filters are up top. can be a bit of mess if you're not careful changing them though.
BlueMoon is offline
