2001 Frontier / Guages Inop
I have a 2001 frontier,3.3,2wd,automatic. The gauges go out sometimes mostly when it's hot. The gauges all bottom out and read at nothing, sometimes when this happens the truck will buck as if there is a fuel problem, I can turn the truck off and restart the truck and it will run properly with no bucking, sometimes I have to restart several times. Once restarted and running good the gauges are still not working, I can park the truck for 10 minutes start it up and it is if nothing happened everything is fine. The engine light never comes on during this process and I have unplugged and plugged the cluster. Could it be a transmission sensor? The truck worked fine for the last 2 weeks then started back again. Thanks Fayetteam
I believe bad grounds can occasionally mess with your gauges, but I'm not sure if thats the problem.
![]() ___________________________________________ '04 Super Black CC K&N intake, Nismo exhaust, Painted Calipers, NGK Iridium IX sparkplugs w/ wires, Nismo Floormats, Street Scene Grill, Sirius, Club Frontier Sticker, PowerSlot Slotted Rotors |
I will continue searching for loose grounds,Thanks Mountaineer!!!
There were intermittent problems with 98-01 clusters (all same backplane) doing just that. Most have had their clusters replaced to correct the problem.
The Sleeper: Waking up at a trailhead near YOU! http://home.sprintmail.com/~onlyone/ It has more mods than I can count or fit on this page. Most of you have a long way to go to catch up... LOL |
Thanks OnlyOneDR; There is a place near here in Atlanta (Speedometer Service).They repair/exchange radios,body computers,clusters etc, I will contact them and price the cluster.
