Old 11-10-2007, 07:00 PM
Mountaineer's Avatar
1st gen trim removal
I'm wanting to know how do I get the trim off around the radio so I can remove the radio and add something I bought for my Sirius. I did a search and only found info on the 2nd gen, it sounds like I could do the same tricks but I was wondering if we have any better ways than puddy sticks.
'04 Super Black CC
Old 11-10-2007, 07:36 PM
Send a message via AIM to Delta
Pull the shifter trim (pull hard, that's what I did) and then you have access to the 4 screws in that area. There are also two more screws under the climate controls (top of the radio). Should be 6 screws in total, and you should be able to pull the trim off and have full access. You'll have to unplug the airbag light, switch, and 12V accessory. Whatever you do don't turn the truck on with them removed.
EDIT:
2004 Nissan Frontier: KA24DE 5 speed.
Old 11-10-2007, 08:30 PM
Icarus03's Avatar
I'm pretty sure the center dash surround is held in by 4 screws total. Two at the top of the radio (hidden), and two more at the bottom of the surround panel that become visible when the shifter surround is removed. Then pull hard but carefully, and the trim panel will come loose. My truck doesn't have the airbag on/off switch so I turned my truck on and off no problem.
Btw, crutchfield is using some kind of prybar which will **** up your trim. Just grab with your fingers on the sides of the shifter surround and the dash surround panel and they will both come loose.
Old 11-11-2007, 01:42 AM
steve0616's Avatar
Mine was 4 screws to get the dash apart and the 4 screws to get the radio out.
2004 Electric Blue CC SB LE:
Old 11-11-2007, 09:36 AM
Mysteria's Avatar
Send a message via MSN to Mysteria
i guess the 1.5 is different then 1.
Mine you just had to take out the ashtray and remove two screws and the top was hinged
2000 Jap Cab (cc) SE
Exterior mods:Flowmaster exhaust tip, blue underbody lights, front and back 5 ton tow-hooks, Silverstar Ultra Headlights , Black headlights, Altezza Tails 1ft Stubbie Antenna, Reverse Lights Relayed to Stock Reverse's
Performance: Traction Bars, Grounding Kit, K&N Drop In, custom built CAI box mod
Sound:Train Horn, Kenwood 4 out and MTX 2 out Amps, Alpine HU w/ipod interface2x 12" MTX 600 Watt BoomBoom-ers.
Problems: Keeping the damn wheels on the ground. Seriously..I added a leaf and put a traction bar on and it still hops
Old 11-11-2007, 09:40 AM
roastbeef's Avatar
will an 05+ radio fit into a 1st gen?
Old 11-11-2007, 02:26 PM
Icarus03's Avatar
They're both double-din. As long as the harness is the same which it should be unless Nissan changed it recently.
Old 11-11-2007, 03:07 PM
Thanks guys, I got the thing installed this morning, no more static interuption while listening to Sirius!
'04 Super Black CC
