theres only one air box,unless your talking about the resonator inside the fender.
![]() Last edited by nicetier : 01-08-2008 at 10:49 PM. |
yea, pull that crap out of there. you don't need it.
i actually cut the neck of the alt resonator and cut a circle out of the actual box and glued it to the tube to make a cap. thats how i plugged it up.
![]() "do you ever feel like you're going to tip?" "yes." |
i have a small problem with mine, mechanics put them in one notch out so they adjuster sticks out from underneath exposed to being hit by rocks etc. Quote:
plenty of choices for lifts, have a read through the forum. i assume D22 (USA 1st gen), then i would add a leaf to the rear (fix the crap rear springs) and wind up the torsions on the front.
'04 D22 Navara ZD30 3 litre diesel power EGR and butterfly mod, catch can, extra rear spring leaf, to muddy to clean! Last edited by Tweak'e : 03-13-2008 at 04:41 PM. Reason: Automerged Doublepost |
One of the most detailed 3" body lift instructions. Body lift for dummies
![]() http://www.performanceaccessories.co...ions/40043.pdf |
NEED MORE POWAAAAH!!!! 0-60 time...well I got burned by a Mercedes 300SD.... Quote:
These are the codes for the 3.3 and 2.4 frontier and exterra
Nissan Frontier Extera Truck 3.3L OBDII Trouble Codes DTC Troubleshooting FRONTIER & XTERRA 3.3L P0000 No Self Diagnostic Failure Indicated P0100 MAF Sensor P0105 Absolute Pressure Sensor P0110 IAT Sensor P0115 ECT Sensor P0120 TP Sensor P0125 ECT Sensor P0130–P0134 Front HO2S RH Bank P0135 Front HO2S Heater RH Bank P0136–P0140 Rear HO2S RH Bank P0141 Rear HO2S Heater RH Bank P0150–P0154 Front HO2S LH Bank P0155 Front HO2S Heater LH Bank P0157–P0161 Rear HO2S LH Bank P0171 Fuel Injection System Lean RH Bank P0172 Fuel Injection System Rich RH Bank P0174 Fuel Injection System Lean LH Bank P0175 Fuel Injection System Rich LH Bank P0180 Tank Fuel Temperature Sensor P0217 Engine Over Temp P0300 Multiple Cylinder Misfire P0301–P0306 Misfire Cylinders 1–6 P0325 Knock Sensor P0335 CKP Sensor P0340 CMP Sensor P0400 EGR Function P0402 EGRC-BPT Valve Function P0420 TWC Function P0430 TWC Function P0440 EVAP System Small Leak P0443 EVAP Canister Purge Control Valve & Solenoid Valve P0446 EVAP Canister Vent Control P0450 EVAP System Pressure Sensor P0500 VSS P0505 IAC-AAC Valve P0510 CTP Switch P0600 A/T Control & Communication Line P0705 Park Neutral Position Switch/Circuit P0710 ATF Temp Sensor/Circuit P0720 Vehicle Speed Sensor/Circuit P0725 Engine Speed Signal P0731 A/T 1ST Gear Function P0732 A/T 2ND Gear Function P0733 A/T 3RD Gear Function P0734 A/T 4TH Gear Function P0740 TCC Solenoid/Circuit P0744 A/T TCC Switch/Valve Function P0745 Low Pressure Solenoid/Circuit P0750 Shift Solenoid A/Circuit P0755 Shift Solenoid B/Circuit P1105 MAP/BARO Switch Solenoid Valve P1148 Closed Loop B1 P1168 Closed Loop B2 P1320 Ignition Signal P1336 CKP Sensor P1400 EGR Valve & EVAP Canister Purge Control Solenoid Valve P1401 EGR Temperature Sensor P1402 EGR System P1440 EVAP System Small Leak P1444 Purge Volume Control Valve P1446 EVAP Canister Vent Control Valve P1447 EVAP System Purge Flow Monitoring P1448 Vacuum Cut Valve P1490 Vacuum Cut Valve Bypass Valve P1491 Vacuum Cut Valve Bypass Valve P1605 A/T Diagnosis Communication Line P1705 Throttle Position Sensor/Circuit A/T P1706 PNP Switch/Circuit P1760 Over/Run Clutch Solenoid/Circuit Nissan Frontier Extera 2.4L OBDII Trouble Codes DTC Troubleshooting List Guide FRONTIER & XTERRA 2.4L P0000 No Self Diagnostic Failure Indicated P0100 MAF Sensor P0105 Absolute Pressure Sensor P0110 IAT Sensor P0115 ECT Sensor P0120 TP Sensor P0125 ECT Sensor P0130–P0134 Front HO2S P0135 Front HO2S Heater P0137–P0140 Rear HO2S P0141 Rear HO2S Heater P0171 Fuel Injection System Lean P0172 Fuel Injection System Rich P0180 Tank Fuel Temperature Sensor P0300 Multiple Cylinder Misfire P0301–P0304 Misfire, Cylinders 1–4 P0325 Knock Sensor P0335 CKP Sensor P0340 CMP Sensor, Detectable & Non-Detectable Circuit P0400 EGR Function P0402 EGRC-BPT Valve P0420 TWC Function P0440 EVAP System Small Leak P0443 EVAP Canister Purge Volume Control Solenoid Valve P0446 EVAP Canister Vent Control Valve Circuit P0450 EVAP Control System Pressure Sensor P0500 VSS P0505 IAC-AAC Valve P0510 CTP P0605 ECM/ECCS Module P1105 MAP/BARO Switch Solenoid Valve P1148 Closed Loop Control P1320 Ignition Signal P1336 CKP P1400 EGR & Canister Control Solenoid Valve P1401 EGR Temperature Sensor P1402 EGR System P1440 EVAP System Small Leak P1444 Purge Volume Control Valve P1446 Vacuum Cut Valve P1447 EVAP Purge Flow Monitor P1448 Vacuum Cut Valve P1490 Vacuum Cut/Bypass Valve P1491 Vacuum Cut Valve Bypass Valve P1706 Park/Neutral Position Switch P1775 TCC Solenoid Valve Circuit P1776 TCC Clutch Solenoid Valve
-Nick- 01 XE King Cab, V6 4X4 ,5 Speed, K&N filter w/air box mod,Clutch switch starter button mod,EGR bed rail caps, Optima Yellow Top, Hyper White Headlights, 2.5" Rancho Lift, Rancho 5000's Bumper To Bumper. Pioneer premier deck, Focal separates with a Alpine amp, Alpine type R 12" sub with Rockford Fosgate 1000w amp W/ a 1 farad cap. ROCKS!!! |
just some fyi, even with t-bar lift some 31's will rub, infact my BFG AT T/A's Rub this is with stock rims w/ about 1 1/2 inches of lift, rubs right on the idler arm and pitman arm, Not sure if this is true for all SE's and LE's but on the first gen XE at least for me its true.
![]() see pics of the truck Here 2004 XE 2.4l I-4 part of The Lifted XE Club! MODS: 1.5" lift, Fiberglass Fenders, Panasonic CQ-C7303U Clarion 4 channel 400W amp pushing a set of JL audio 6.5 Compents, MA Audio 400w 2 channel amp pushing Kicker Comp 10", XM Radio, Magnaflow 2 1/4 in/out dumped before the axle. 5% tint on rear windows 35% on front windows, oval fog lights from kragen. Soon to be mods: Total Chaos Long Travel Kit, Custom shock hoops/engine brace Future mods: Rear Deavers So your wondering about to total amout of cash i spet on mods... Well lets just say front alone w/ the TC kit is 5000+
I just read the torsion bar write up. SO i dont have to adjust the bottom of the bolt at all? I just loosen the lock nut and then adjust the torsion nut? I thought the torsion nut was supossed to be welded to the cross bar?
03 Frontier S/C 4x4
