Old 05-27-2008, 09:52 PM
02 Nissan Frontier 4X4 Transmission problems???
Has anyone had any problems with there transmission with this year and make???
Sorry I didn't post what was wrong with mine. I have an automatic transmission and it shifts very hard generally into 2nd and third. It will jerk the whole truck sometimes!!! It seems tell help when I know its about to change gears if I ease up on the gas.
Is this something to worry about??? Is my transmission going to die ??? I have owned the truck since october and it has been doing it since then, sadly I didn't notice it when I bought it...
Thanks,
andy
Old 05-28-2008, 06:20 PM
TxFront's Avatar
If you post what problem you are having with your transmission. Then the great people of CF will be able to help you out.
2003 CREW CAB
Future Mods
Old 05-28-2008, 06:43 PM
daves d22u's Avatar
i had a slipping problem fron 2nd to 3rd. i brought it into the local performance trans shop and had carbon fiber clutches put in and they reprogrammed the tcm. was a 1200 dollar fix.
Old 05-28-2008, 07:41 PM
03 4x4 manual trans blew up
2007 nismo crew cab 4x2 banks exhaust, volant intake, and tbs
2008 nismo king cab 4x4 prg 3 inch spacer, 285/75/16 mickey thompson mtz's
Old 05-29-2008, 12:53 AM
kor0000's Avatar
Sounds expensive.
I don't have the same truck, but I had a similar issue with my 94 Hardbody auto 4x4. I towed a jeep home on a chain and BAM my tranny was never the same. The good news is I never had mine fixed and just learned to live with letting off the gas at the shift point and I've put many tens of thousands of miles on it sense then. It never got any worse.
