» Sponsors
» Sponsors
Go Back   Nissan Frontier / Navara Forum > Site Sponsors > PRGProducts.com
Old 12-18-2008, 06:08 AM
Aussie Frontier's Avatar
Radflo/Eibach Problems
I have a 07 Navara/Frontier 4x2 and have just installed the Radflo's from PRG that finally came over in the slowest boat. Anyway these are my springs
My problem is that nothing I do will being the damm truck down. Its riding very high and I have almost no adjustment left to bring it back down so I can get the camber in.
I have tried to figure out the specs of the springs from Eiback charts n stuff and it appears to be
1200 means 12"
0250 is 2.5 inch dia
0700 is 700 pounds per inch
thats from the
1200.250.0700 the lower number on the spring so thats the number I need from others members setups .
More stuff
spring length with wheels lifted off ground 265mm
springs loaded wheels on the ground 240mm so the full weight of the truck pushes the spring down a full 25mm or 1 inch
Now I aint no rocket scientist but 700lb is 318kg so that setting sounds about right.
The truck is 1850kg in total so lets say 60% of the weight would be front axle so lets say 1000kg which would equate to 500kg per front wheel.
you cant tell me that 500kg on that from shock would only move it 25mm.
Like I said before I suspect the springs are the issue and they arent marked right.
So if someone can have a peek at their springs and see if they are marked same or similar and tell me how much defelection they get that would be kool.
Black Ice
Dodgey Midnight Black with some Frontier Bits
Wheels by Speedy Australia
Paint screwed by Nissan Australia
"The only true Wilderness is the space between a Tree Huggers ears "
Sponsored links
