Go Back   Nissan Frontier / Navara Forum > Site Sponsors > PRGProducts.com
Old 07-21-2008, 02:03 AM
Deaver Pack
Any one can chime in on this but I just wanted to get it in the right place for Greg to definately see it. I wanted to know if the deaver pack will basically serve as a helper spring or if it is basically just a lift. I want the back end of my truck to be a little stiffer and be able to support a little more weight in the bed. The way I put my quad in my truck makes the back end sag a bit because I have a custom built box in the bed so it pushes my quad about 12-15" back so theres a little more weight to support. Just wanted to see if the deavers would fix it or if I should look for a helper spring somewhere. Any and all input is accepted and appreciated. Thanks.
-Jason
06 SE KC 4x4 - Black
Old 07-22-2008, 12:35 PM
Bump
-Jason
Old 09-08-2008, 08:00 PM
Mr. Plow's Avatar
Looks like nobody has helped you out w/ this; Im not an expert but I can tell you what I have heard about the Deavers. When you install the deavers you normally remove the overload spring. This gives it a softer ride, but reduces the trucks ability to tow/haul heavy loads. If you want stiffer leaf springs I would look into Alcan, as they can custom build springs to match the amount of lift or load you want to carry. I think Greg carries full replacement leaf packs too that might work out for you.
Silver 06 Frontier KC NISMO 4x4. Mods: PRG Radflo 2.5" SL; Deaver 10 Leaf Springs; AC Rear Diff Skid; Shrockworks Sliders/Skids; KMA Front/Rear Bumpers; Warn M8000 Winch and Offroad Lights; Gibson Exhaust; Interco Trxus MTs 285/75/R16 on MB Predators
Old 09-08-2008, 08:22 PM
stevet47's Avatar
I think Greg recommends removing the overload when installing the deavers for sake of ride quality and flex, but if load capacity is your main concern, and not flex, you can keep the overload with the deavers. The deavers should increase your carrying capacity a bit, but not a whole lot. However, they are the only lift option that will increase it at all. Blocks wont and shackles wont, so they are your best option unless you wanted to go with an air-bag type load support like this:
Air Lift Company - Load Support
05 Frontier KC Nismo 4x4.
Old 09-09-2008, 12:48 AM
Thanks for the feedback guys. I think I'm going to order a set of helper springs though.
-Jason
