yea it looks that way. plus it will be the orginal parts back on the truck. do you think i should do the lower control arm also. right now its just the left side upper
did you have to do the control arms on yours Last edited by zwilke : 11-04-2007 at 10:21 PM. Reason: Automerged Doublepost |
i put 3 inch lift calmini arms on, they came with new bushings.
havent touched the lowers, how can you tell if it needs them?
it started when i have heard a clunk when turning right. after checking everything out over and over again i jacked the truck up and the bushings have what looks like rubbing on the brackets. so i looked at it more and turned the wheel while up in the air and i am hearing it still . i think i will take it somewhere just to be sure
ok, also try the sway bar links
i checked those out and it looks like they might be pushed out a little bit
i just replace both end links unless i am thinking of the wrong part how many mile are on your frontier Last edited by zwilke : 11-04-2007 at 11:55 PM. Reason: Automerged Doublepost |
