For TS you'll need either the PRG Tie rod extenders or Titan inner and outer tie rods.
With your steering wheel centered, do your best to adjust the tie rods to keep the wheel pointed forward and limp your way to an alignment shop.
I got the Firestone Lifetime alignment because between, fine tuning my setup and wheeling, Id need to get adjusted a few times to make the cost worth it.
