Old 07-01-2008, 02:57 PM
Inyourface1650's Avatar
Originally Posted by tomtom View Post
Also wondering if this changes the jacking points? Can you still use the rocker panel jack points with this jack? What if you have rails or sliders? If no then I assume you've got to buy the bumper lift accessory too.
Pretty mcuh the only places I would use a highlift would be on a Shrockworks/KMA bumpers or rock sliders. I also have been highlifted on my tow hitch once.
You cant use any stock lift points.
2007 NISMO KC 6M 4x4 - Gone
2005 SE KC 6M 2x4 - Gone
2002 SE CC 4A 2x4 - Gone
ONAZ
Old 07-01-2008, 05:19 PM
bigdog's Avatar
OK, thanks that answers the question.
2006 SE CC 4x4 A/T:
Old 07-01-2008, 07:33 PM
Mainerunr's Avatar
I've got two 12" long 2x4's behind the back seat because I've never used the factory jack and have no idea if it's tall enough anymore.
Old 07-01-2008, 07:34 PM
TruckGal81's Avatar
Send a message via AIM to TruckGal81
I know this is obvious once you think about it, but it did not occur to me until I was on the side of the road with a flat tire. Lucky for me there was an old fence post leaning up next to a building where I pulled over. By putting the jack on top of the 4" x 4" post I was able to get the front wheel high enough to replace it. But only just barely, once I get to the 33" tires a 4" block will not be enough.
Anyway, I figured that I would post a quick thread reminding folks that if you do lift your truck you need to make arrangements for your possible jacking needs. If I'm the only moron that did not think of this, then shame on me
Also wondering what others with lifts have replaced their jacks with, as I am now looking for a better option then the block of wood.
This is actually one of the first things I thought about after I lifted the truck a couple of weeks ago. I just picked up a new jack at walmart last night... $35 more bucks, but at least I know I won't be stranded if I blow a tire! Actually, I have yet to even try it with the truck to see if it gets the tires off of the ground. I know that even our 3-ton floorjack at work barely gets the tires off of the ground, but I'm not sure how high it goes. Guess I better check that soon...
2007 Silver CC SE 6spd - Lorado tonneau, hitch, Eclipse AVN2210P double din, Pioneer speakers, silver painted center dash, custom seat covers, 350z shift knob and black boot, Calmini 5", 2" front spacers, radflos, Dynomax catback and 285 Terra Grapplers. AAL, blocks, and shackles in the rear. aFe intake, foglights, and pathfinder switch covers. Still to come: xterra roofrack, kenwood sub and amp, sound deaden entire cab, 2" DIY bodylift, sliders, wheels (maybe), fire and ice light strip.
http://profile.myspace.com/index.cfm...ndid=358307623
Old 07-01-2008, 10:56 PM
WhistlerWzrd's Avatar
Mustard has got it right, the Wzrd always carries some 2X6 boards nailed together one set of two and one set of three, they are also angled cut on one side for lifting one wheel up on hard surfaces, on soft surfaces, you get a better jack angle, and more square inches of stable lift surface whether it's mud, snow, or sand.
WW, '91SEV64X4 Hardbody, '05 NISMO KC Fronty, K&N filter, 22" Magnaflow. Nissan Bugflector. '08 Rogue SL AWD.
Old 07-02-2008, 11:56 AM
bigdog's Avatar
Originally Posted by mustard23 View Post
get a scrap of 4x4, nail a 2x4 to it and put that under your jack and your done, if you don't wheel, and your not going to use hilift then save your self the money, you don;t have bumpers or sliders you don't realy have a front jacking point for a hilift.
ok, so that is already my temporary solution. The block of wood (trimmed down from the scrap fence post) fits nicely behind the seat. I did tear up my step rails at URE last weekend, but banged them back into place until I can afford a set of schrock sliders. Wheels are on backorder, and once they arrive the tires will be next purchase. I guess all I can say about the Nissan step rails is - better them then my rocker panels!
Sounds like the block of wood is the best solution until the sliders go on. The good news is now I know I need it.
2006 SE CC 4x4 A/T:
Old 07-02-2008, 02:03 PM
mustard23's Avatar
can use one of these like the desert guys do, but your looking at 3 to 4 times what a hilift costs.
I had jack ball and weinersnitchel weiner antenna topper stolen from my truck.. so screw that I'm not moding it anymore
Old 07-02-2008, 02:47 PM
bigdog's Avatar
Yea, I actually have a small floor jack in my garage, guess I should see if that will lift the truck.
2006 SE CC 4x4 A/T:
  #19 (permalink)
Old 07-02-2008, 04:15 PM
gr8-wrx's Avatar
In my case, I'd probably call AAA first, but you've got a good point.
I used to rotate my tires myself, but since getting a truck, I've been letting CostCo do the rotating. Call me a wimp, but I'm getting too old for this...
2008 Nissan Frontier Crew Cab SE (shortbed)
2003 Subaru WRX sedan + Cobb Tuning Stage 2
2001 Honda CR-V SE
The Following User Says Thank You to gr8-wrx For This Useful Post:
Rusty.gh (10-15-2008)
  #20 (permalink)
Old 07-02-2008, 04:36 PM
of course, if you guys lift using suspension componants, it really doesnt matter does it? You can jack up the appropriate A-arm up front for the tire.....and you can just put the jack either under the axle tube or under the Ubolt plates, and lift there. that stuff might be a tad higher (a 1/2 inch?) due to 33' tires...but...
ONAZ
