Rancho Quick Lift
Has anyone used the Rancho quick lifts shocks linked below as an option to provide a lift rather than a lift kit? What are your thoughts on these? I wonder how good of a job the shocks would do at holding air pressure. I used to have an F-150 with air helper springs and the air would always leak out after a few days. It says you can go to a bigger tire with these Ranchos, but if the air were to leak out, the tires would rub, so I'm not sure if it's a good idea. Used the search button, but found nothing on these.
Thanks! PerformanceLifts.com -- Rancho QuickLIFT 2005+ Frontier & Xterra Hmmm. After reading this again, it says the ride height gain is 2" and not adjustable. Looks like the pressure is adjustable. Maybe they may be OK for me. I don't do much wheeling, I just want my truck to look better and to be able to fit 32s or 33s.
2008 Storm Grey Frontier Crew Cab Nismo 4x4 Automatic Last edited by maclufrontier : 08-01-2008 at 11:05 AM. Reason: Automerged Doublepost |
i think just one person said they had those, but that was a while back.
since you have the nismo, a cost effective lift would be bilstein 5100 adjustable height shocks. I had these for a couple of weeks before upgrading to saws. take a look here Trying out some new stuff from Greg
![]() ![]() ![]() ![]() '007 2wd Nismo; Titan swap, Superchips tuned, other stuff Last edited by bigriver : 08-01-2008 at 12:33 PM. |
Thanks!
2008 Storm Grey Frontier Crew Cab Nismo 4x4 Automatic |
These are the titan adjustable height bilsteins. You will need to swap your nismo coils and spring perches onto the titan bilstein. Greg did mine with his lathe and only took 5 minutes.
You might to check out the ones for the frontier if they are available. I really liked them, but when I got some additional cash, I went with the saws.
![]() ![]() ![]() ![]() '007 2wd Nismo; Titan swap, Superchips tuned, other stuff |
