I Hate Slip - gonna put back on my 265/75/16's and sell my NISMO!!!!!
How frustrating! I put on a PRG leveling kit, 2" front, 1-1/2" rear, and a set of Toya M55's - 285/75/16's on my '07 Crew Cab Nismo. Now the VDC can't handle tight turns on paved mountain roads without kicking on. The air pressure is right, the alignment has been checked twice, and no, I'm not haul'n fast around these turns. The Frontier seems to be a truck that is great as a stock work truck, or as a lifted rig for those who don't mind the sacrifice and annoyance of VDC and ALBS going wacky when they are no longer attached to stock suspenison and tires. I hoped I'd find a beefed up NISMO would be the perfect balance of street ability and mildly agressive off road worthyness.....not.
makes me glad i dont have auto and all that jazz but maybe someone else with those options on their truck can shed some light to it?
CALMINI sucks! ![]() ![]() ![]() |
ever thought that the new tires might just SUCK..
i have the same size tires and the only time i get a slip light is when its wet and/or iam actually trying to spin them.
'06 CC NISMO 4X4 STORM GREY W/ RF SYSTEM VISUAL MODS: 5% TINT(1% TOTAL ON REAR), SILVINA SILVERSTARS, 9" AMI STUBBI, PATHY SWITCH COVERS, RED LED WINDOW SWITCHES, HELLA 500's ON CUSTOM LIGHTBAR PROFORMANCE MODS: FLOWMASTER 50 SERIES SUV, AIR BOX MOD, K&N DROPIN, PRG 3" FRONT LIFT, (2" REAR SOON), 285/75-R16 DICK CEPEK FUN COUNTRY II AUDIO: ECLIPSE CD5000, CDT AUDIO COMPONENTS, 2 10" JBL's, ROCKFORD FOSGATE PUNCH 325.2, STEP 1 OF "BIG 3" UPGRADE |
have you checked out the ABLS bypass mod? when you pull the abs fuse it turns off all that fancy stuff like ABLS...im not sure about VDC though..
Sounds like you have a problem. Nobody elses truck does this.
Third Coast Nissans official page on Facebook 2005 Nismo CC: Titan Swap'd, Bilstein 5125's, BFG MT's, Shrock sliders, White Rhino light bar, Hella 500's, 2* Adv., Magnaflow exhaust, Airaid intake, Stillen rotors, Metal Matrix pads, Graphite wheels, Manik TL guards, Kenwood DD HU, Sirius, Infiniti 12 and tweeters, 600w amp, in-channel vent visors, Pathfinder switch covers FUTURE MODS: Wouldn't you like to know!
X2
should get the nismo without the vdc option. what year is your truck? if my memory serves me right i believe the '05 models had vdc stock. our '05 xterra does, while my '07 nismo does not.
Sounds like you may have a code set off from the lift install/alignment. Have the dealer check it with the Consult, but if they don't find anything you may have to pay for the diagnostic time. If they find, say a Steering Angle code then it should be covered under warranty and easily reset in under 30 min. Or you could just sell it and live with the loss?
As for mine, it came with a switchable VDC (early '05 build date) also lifted with 285 mudders and no unwanted "slip" |
Slip
Thanks for the thoughts and info.
It's an '07 with VDC switch on the dash, so I can turn it off. Even with it off the VDC kicks in. I think the tires are ok, but just happen to be a bad mix with the VDC. The shop checked for error codes and there were none. I'm tempted to slap on a set of used BFG's of the same size and see what happens. |
