Old 05-10-2008, 08:04 PM
toyniss's Avatar
^^^^^if you turn your vdc off then its off-you either are still feeling the abls slipping or you have a problem.
CALMINI sucks!
Old 05-10-2008, 09:54 PM
mudyfronty05's Avatar
No VDC here.
'05 EB CC NISMO 4X4 MODs-Nissan toolbox-PRGproducts. com 3in lift with T\C arms, radflos and Deavers,Bilstien 5125's-265/75R16 Firestone Destination M/Ts-Volant Cold air intake!, Trail Gear Rock sliders
Old 05-11-2008, 12:05 AM
Whats slip?
At first i thought you meant limmited slip, you might be better served in say a tacoma from your sig. I had 1999 tacoma trd with 31s and that darn thing went places my jeep wrangler went. Went up step snow covered hill, new home being built in Park City Utah, sucker went all the way up 2 feet deep with the locker engaged! Only time i ever used it lol, most of my wheeling i used wrangler its simple and straight forward predictable.
Old 05-11-2008, 12:31 AM
Originally Posted by salsierra View Post
Thanks for the thoughts and info.
It's an '07 with VDC switch on the dash, so I can turn it off. Even with it off the VDC kicks in. I think the tires are ok, but just happen to be a bad mix with the VDC. The shop checked for error codes and there were none. I'm tempted to slap on a set of used BFG's of the same size and see what happens.
Just curious, which shop? Was it a dealer with a Consult? If not may it may be worthwhile to have them take a look using the Consult and not a Generic Scan Tool (GST). I have seen some GSTs miss codes that the Consult finds on Nissans.
I'm not certain you have a problem from what you have described although some think you have a larger issue. If there are or are not any code(s) you seem to think it's the tires, but you are not the first with that tire combo. Again, makes sense to have it checked out. Do you actually feel & hear the system "kick in" or just see the SLIP light when the VDC is "off"?
Either way, I'd use MY warranty. Besides it would be cheaper to use your warranty than to service out and buy new/used and rebalance wheels & tires etc. Then again, you may be right. Let us know how it works out. Good Luck
Old 05-12-2008, 12:42 AM
toyniss's Avatar
and the nismo locked will go the same places, hes refering to abls and his vdc kicking in.
CALMINI sucks!
Old 05-13-2008, 01:44 PM
Spawkum's Avatar
Originally Posted by mike View Post
X2
x2
shift_nismo
-2007 Radiant Silver Nismo 6 spd, Nissan Sliding Tool Box, K & N Air Filter. Alpine Ipod compatible deck, 500 watt Kicker amp, JL w1 12" sub. eagle eye 6k hids, prg uca's radflo 2.0's cranked to 4in., ss brake lines, deaver 2 pack, 2 in. adujtable shackles, bilstien 5125's, 1 in. wheel adapters in front, 16 x 8 aluminum raton rims w/ 305/70/r16 mickey thompson baja claws, lawn edging flares.
Old 05-13-2008, 03:44 PM
Nissan4Life's Avatar
His VDC or his ABLS. My ABLS kick in all the time on dirt. Stock sized tires. But I am slippin.
We really need to figure out a better ABS/ ABLS bypass. Come on guys work on it!! Pulling the fuse sucks!! or doing the fuse bypass. Turns off all of your functions. Speedo, trip computer, 4wd shifting cylindoid. I was playing with bypassing the fuse inside the ABS computer by putting a toggel on the fuse output wire from the harness. I started a thread on this a little bit ago. The abs fuse in the fuse box is labled "ABS ECU" and it does alot more than jsut control the abs.
06 KC NISMO 4x4, 2" prg spacer front, Firestone riderite airbags rear, Schrockwrxs front engine skid, Custom sliders, Hidden hitch reciever, Deck plate Airbox mod/amsoil filter, Momo shift knob removed, back to 06+ nismo knob, 05 pathy flat black wheels, 265/75/r16 mud king XT studded, wireless door lock keypad, cargo light bypass, auto dimming rear view mirror with compass and temp
Old 05-13-2008, 04:13 PM
Pops's Avatar
The M55 is more of an onroad tire with some offroad traction ability. Seems to me that problem wouldn't likely happen with the Open County A/T or M/T. The Armada comes standard with VDC & ABLS so ppl who aren't used to it have this issue and the Traction Control Module from KP Tech seems to help them for the most part when used it remembers to leave the VDC Off for you. KP Technologies
IMHO, I think you're running on the wrong tires for driving in the dirt.
2005 Armada LE 4x4 - 2* Timing Advance - AirBox Mod - PRG Mini-Lift - Nitto TerraGrapplers 325/60-18
_____________
. Check out my Gallery! .
  #19 (permalink)
Old 05-16-2008, 01:32 AM
And now things get interesting. The cold PSI rating on these tires is 80. The shop set them at 60. Today the TPMS light went on just as I was thinking about upping the pressure a bit. Oh heah, the shop filled the tires with nitrogen. The VDC just seems to be soooo sensitive with these tires. I seem to have entered a black hole with this truck.
Anybody in the San Francisco Bay Area have a used set of 285/75/16's they'd like to sell cheap. I'd love to see if a simple swap of tires settles this issue.
  #20 (permalink)
Old 05-16-2008, 01:41 AM
Inyourface1650's Avatar
I must admit, I have never heard of slip or VDC issues with a lift before....
2007 NISMO KC 6M 4x4 - Gone
2005 SE KC 6M 2x4 - Gone
2002 SE CC 4A 2x4 - Gone
ONAZ
