Old 05-08-2008, 10:26 AM
Silverback's Avatar
Feedback on coil lift.
I have the 2 1/2 coil lift from 4x4 parts and wanted some reviews before I installed them.
2005 Nissan Frontier Nismo Crew Cab 4.0 liter V-6 4x4...PRG mini lift/Truxedo tonneau cover/ Window tint/ Pathfinder brushed aluminum switch plate covers/ Bed extender/ Manik prerunner bar/ Nerf bars/ Baja fog lights/ Hi lift jack/ Mag lite mount/ Hood struts
http://www.cardomain.com/ride/2948574
Old 05-08-2008, 10:45 AM
I assume you mean the AC coils that are extremely rough and really need to be broken in? If so, you defiently need a shop to install the coils on the shocks, they are just so stiff. You will notice a stiffer suspension which you may like or not, there are members on both sides of this debate.
Old 05-08-2008, 11:03 AM
Silverback's Avatar
Yes, they are the AC coils I bought them from another member who had them on his truck for a couple years. So maybe they won't be so bad. Any other feedback on these?
Old 05-08-2008, 11:07 AM
That means they are probably broken in and should be a lot better then if they were new. I would still suggest that you have a shop install the coils on the shocks and then you can do the rest.
Old 05-08-2008, 11:15 AM
Silverback's Avatar
I have a shop that is going to install them, I was just wanting to get some feedback on them before I had them installed.
Old 05-08-2008, 11:17 AM
penski61's Avatar
yes they are pretty stiff but its because the shocks you have limit down travel and the coil being so stiff limits up travel , the radflo's with the 750lb spring rate are the same spring rate as a/c but the reason the radflo's work so well is cause the shock has the travel to work with the springs , i just took the ac coils off off my truck because you have like 1/2 of down travel and the ride sucks , unless u can find a longer shock which we havent been able to do id decide against it
pass side with ac coils , right side with radflo's , hope this helps
Old 05-08-2008, 11:56 AM
Silverback's Avatar
Does the ride suck in general or is it more when your off road?
Old 05-08-2008, 12:07 PM
penski61's Avatar
pretty much both for me , think of it this way , with a spacer lift you still have the factory ride except the uca is closer to the coil bucket , with the ac springs you have a higher spring rate coil compressed to the point where u have no movement in the spring and shock which results in the stiffness everyone complains about
this is just my opinion but i didnt like them for ride quality at all
Old 05-08-2008, 05:56 PM
Nissan4Life's Avatar
I heard they break stock shocks as well.
06 KC NISMO 4x4, 2" prg spacer front, Firestone riderite airbags rear, Schrockwrxs front engine skid, Custom sliders, Hidden hitch reciever, Deck plate Airbox mod/amsoil filter, Momo shift knob removed, back to 06+ nismo knob, 05 pathy flat black wheels, 265/75/r16 mud king XT studded, wireless door lock keypad, cargo light bypass, auto dimming rear view mirror with compass and temp
Old 05-09-2008, 03:49 PM
TruckGal81's Avatar
Send a message via AIM to TruckGal81
I've had mine on for about 6 months/5000 miles with stock shocks. No problems as far as stress on the shocks, but I don't offroad. I actually have to slow down at speed bumps now, which I don't really appreciate, but on the positive side you've got a firm ride going around corners and such. All in all, I'm thinking of replacing the setup with the calmini or fabtech lift, which is what I probably should have done to begin with but I was being cheap and didn't think I would get lift hungry again so soon!
2007 Silver CC SE 6spd - Lorado tonneau, hitch, Eclipse AVN2210P double din, Pioneer speakers, silver painted center dash, custom seat covers, 350z shift knob and black boot, Calmini 5", 2" front spacers, radflos, Dynomax catback and 285 Terra Grapplers. AAL, blocks, and shackles in the rear. aFe intake, foglights, and pathfinder switch covers. Still to come: xterra roofrack, kenwood sub and amp, sound deaden entire cab, 2" DIY bodylift, sliders, wheels (maybe), fire and ice light strip.
http://profile.myspace.com/index.cfm...ndid=358307623
