Dakar Leafs - Nissan Frontier Forum
post #1 of 29 (permalink) Old 11-03-2012, 08:36 PM Thread Starter
Stezzyfrontiers23's Avatar
Dakar Leafs
Question i just got some used Dakar Leafs and i want to remove the Blocks underneath it but they wont budge i tried using a hammer and a flat head screwdriver but no luck any suggestions??
Stezzyfrontiers23 is offline
post #2 of 29 (permalink) Old 11-03-2012, 08:51 PM
05Fronty4x's Avatar
It probably wouldn't hurt to leave them unless you are worried about too much lift? It looks like the center pin is holding the leaf pack together, in which case you will have to take them apart to remove the shim block and then re install the pin.
Sidenote: carefull when standing on rotating, reclining office chairs, lol.
2012 Pro-4x CC
05Fronty4x is offline
Stezzyfrontiers23 (11-03-2012)
post #3 of 29 (permalink) Old 11-03-2012, 09:07 PM Thread Starter
Thanks dude!! so I would have to take off the top bolt to remove the block then just reinstall the bolt? and yes i really dont want that much lift in the rear end.
ill take your advice about the chair too almost ended up on the leafs. lol
post #4 of 29 (permalink) Old 11-03-2012, 09:20 PM
05Fronty4x's Avatar
Correct.
Devise some sort of clamping method first off to hold the leafs together before you start loosening the nut. Springs under compression can be dangerous if not handled properly, and you want to keep them squished together. There's no way to know how much force is contained there, but I would atleast tighten up a couple C-clamps on them and make sure they are solid.
Maybe you are already aware of all this, but I had to add it in.
2012 Pro-4x CC
post #5 of 29 (permalink) Old 11-03-2012, 10:14 PM Thread Starter
Alright so I would probably have to get some heavy duty steel c-clamps. And thanks again man ur a ton of help.
post #6 of 29 (permalink) Old 11-03-2012, 10:28 PM
05Fronty4x's Avatar
I'd definately get a couple if you don't have any. I can't imagine any name brand c-clamp not being strong enough. I only say get 2 because you want to even the load, and since you can't put one in the center, I would put one just outside of the aluminum shim/block on each side.
2012 Pro-4x CC
post #7 of 29 (permalink) Old 11-10-2012, 06:23 PM
Those are degree shims. They're meant to rotate the pinion slightly to help prevent possible vibration due to the lift provided by the springs. Some vehicles need them and some don't.
Kevin
kd7kmp is offline
The Following User Says Thank You to kd7kmp For This Useful Post:
mdawg4x4 (11-13-2012)
post #8 of 29 (permalink) Old 11-10-2012, 08:36 PM Thread Starter
That is very interesting information i'll hold on to the shims for a bit longer.
As of now they are off the springs and will be going on the truck in about a week or two. Thought i'd up load a pic of the removal of the shims just cause LOL Two Husky Clamps, 14 mm socket, & socket wrench are the only tools needed.
BEAST!
post #9 of 29 (permalink) Old 11-13-2012, 07:44 PM
Quoted: 11 Post(s)
those are med. duty leaf spring right? I'm loking to get some, but cannot find any information about load capacity. I know that they're suppose to better handle a constant load up to 400lbs, but what about MAX load? Do they help haul heavier loads?
thanks
2011 sv 4x4 cc long bed.
4 wheels with tires
a steering wheel
lights and lamps,
glasses where needed,
and lot of satisfaction
chijusa is offline
post #10 of 29 (permalink) Old 11-13-2012, 08:07 PM
mdawg4x4's Avatar
Quoted: 25 Post(s)
Kevin
I am in agreement with Kevin. If those springs were designed for the Frontier, they probably designed them to use the degree shims for a reason.
06 NISMO CC 4X4: 2 1/2" lift w/285/75-16 BFG MT KM2s, Alpine CDA-9857 HU, Alpine Type R 6.5 components in front, Type R 6.5 3-way in rear, Flowmaster 40, NISMO CAI, NISMO radiator and oil fill caps, Bushwacker Flares, Calmini winch bumper w/Warn 9.5cti, KC SlimLites, and PIAA 510 fogs
98 Jeep Wrangler: 2" spacers, Rubicon coils, Borla Header/Flowmaster, 33-12.50 BFG MTs on 15X8 MT Classic Lock, KC 150W Daylighters, Pioneer HU and speakers w/RF 12" P3 sub and MTX amp
1963 Nissan Patrol L60 (project): 2013 Xterra PRO4X (wife's): 2012 Xterra SV 4X4 (daughter's)
mdawg4x4 is offline
