Old 07-19-2008, 07:21 AM
What is the best cleaner to get that nasty mud color off of the underside ???
Aloha all,
Ok, i havent found a good cleaner yet. But the under side of my truck is brown. I dont know how to get it off.. I know that when you sell it the dealer makes it look almost brand new.
I am also looking for the best option to clean under my hood...
Many thanks!
Thank you,
Greg (a.k.a Wizzard005)
Website: http://www.toy4runner.com Photo Gallery: http://wizzard005.smugmug.com
Lift: PRG 3" Spacer w/ 1.5 Shackles + 1/2 Blocks in the Rear | Tires: Nitto Terra Grappler 285x75x16
Toons: Pioneer AVIC-F700BT | Eclipse 4 Channel Amp | JL Audio 300.2 | Pioneer Shallow Mount Subs 2x 10"s | Eclipse 6x9 Comps Front | Eclipse 6.5's Rear | Audio Quest Speaker Wiring 4pair
Lights: HID's 6000k 9007 Bi-Xenon Headlights | HID's 6000k H11 Fogs
Older Cars / Trucks: 2003 Lexus IS300 (Sold) 1996 Toyota 4Runner SAS'd (Sold) 1998 Dodge Ram 1500 (sold) 1998 Toyota Tacoma (Sold)
Old 07-19-2008, 07:28 AM
silentsamurai's Avatar
Send a message via ICQ to silentsamurai Send a message via AIM to silentsamurai
hey wizard.
for under your truck your gonna need to get yourself a pretty good degreaser. I myself haven't tried anything other than meguiar's all purpose cleaner/degreaser. the stuff is a 20:1 solution and is very potent. or you can try a simple green max stuff they sell in gallon tubs and let it soak for a bit.
For under the truck you absolutely need to get a pressure washer. that's how you make it spotless.
As far as engine bay:
pressure wash (for best results), purple power degreaser / APC+ 10:1 (all purpose cleaner), and a hyper dressing 3:1
Hope that helps.
Adam
Rise up! gather round
Rock this place to the ground
Burn it up let's go for broke
Watch the night go up in smoke
Rock on! Rock on!
Old 07-19-2008, 01:16 PM
Cheapshot's Avatar
Wizzard,
In response to your post check out this website. (Tornado Products Co. - St. Albans, WV) Tornado Products - Home This is a product called Tornado and it is sold out of St. Albans, West Virginia. It is a multi-purpose cleaner that you can dilute and is strongly recommended to dilute to 50% tornado and 50% water. Use it in a spray bottle, apply and watch the dirt, grease, and oil run off. It really is a strong cleaner and is well worth looking into.
Old 07-19-2008, 01:29 PM
MrEd's Avatar
I have heard a few times never use a pressure washer on motorcycles, engines and similiar things, the reason being-it forces water into places that water could not normally get...what do you guys think?
07 SE CC LB 4X4 STORM GRAY
2"LIFT, HELLWIG REAR SWAY BAR, 265/70/18 SHOES
Old 07-19-2008, 01:50 PM
nebraskafrontier's Avatar
as long as you arent shooting directly at critical engine electrical components (fuse boxes, coils, sensors) you should be all right.
a health dose of simple green on a cool engine and washed off ten minutes after it sits does wonders. thats what i do and just rinse it off with a hose.
2006 SE kc. 4x4 6spd. Storm gray. calmini 2.5'' lift. 255/85 Maxxis Bighorn(ey)s. De-badged.
No person was ever honored for what he received. Honor has been awarded for what he gave.
- Calvin Coolidge
The Following User Says Thank You to nebraskafrontier For This Useful Post:
MrEd (07-19-2008)
Old 07-21-2008, 09:09 AM
ToddG's Avatar
x2 on the Simple Green. If you have neglected the engine bay and it's exceptionally dirty use a towel or scrub brush on the tough spots w/Simple green.
Also, I never use the pressure washer in the engine bay. The garden hose works just fine, and no direct blasting of electrical items.
Wizzard, I'd pressure wash the underside first. Then soak with a basic de-greaser as mentioned above. Pressure wash again. Scrub brush for tough/visible areas. I have a brush I use specifically for wheel wells.
To dress the wheel wells I buy the el cheapo tire shine and spray the heck out of them. It's oily so make sure it's mostly dry before hitting the dirt/sand.
Old 07-21-2008, 03:52 PM
Purple power in a foam cannon, let soak for a minute or two, then pressure wash off. Dress all your plastic trim and inner fenders with a non-silicone dressing like Optimum tire shine.
2005 Electric Blue LE CC 2WD
Clarion DXZ765MP Head Unit
Planet Audio 6.5" Components
Power Acoustik LT480/2 Amp (Works better than I thought it would!!)
1996 Lanzar DC-10 SVC 4 Ohm Sub
Mid 90's Orion Cobalt 702 Amp (I like the old school!)
Xact Visor Sirius Tuner
Harmon Kardon Drive+Play iPod module
