Water Spots
I have horrible water spots on my windshield. I mean God awful, can barely see at night sometimes, water spots. I've tried waxing it, I've tried Windex/newspaper, everything I've heard of. Does anyone know how to get rid of them?
Thanks in advance.
99 Frontier 4x4 King Cab V6 SE Black - AAL, 31's, T-bar crank, K&N, UWS tool box, tinted windows, JVC headunit Next mods: Pro Comp series 97 wheels, finish out suspension (UCA's, shocks all around, shackles) Problems: Carrier bearing, horribly rough idle, very rough shifting transmission Go Tarheels |
I found that white vinegar, and a good microfiber towel will take the water spots and stains off glass, plastic and paint with very little effort. Little effort means you will not put any fine scratches in your glass, plastics or paint finish. It will keep it looking perfect. Then go over the areas with the proper wax, polish or cleaner. The less rubbing the better.
Sweet. I will try that tomorrow. Thanks.
Any other suggestions are welcome.
Lime-away works.....or you can go old school and scrape with a razor blade..
here's my sig.....
I tried CLR and it didn't work :/
I figured it would do the same as Lime-Away.
fine steel wool and either windex or white vinegar. used to use it on my glass T tops of my Z28.
05 LE CC 4X4. SUPER BLACK |
I hate waterspot!!
why did i choose a black frontier!! :'(
A lost Stang in a world of Frontiers... 2008 Ford Mustang: Premium Coupe V6, Phony package, and that's about it |
^^^Cause black looks sexy when all clean^^^
the steel wool works excellant but before everyone sees this and uses steel wool on everything clear on their car CAUTION do not use it on plexi glass only on realy glass otherwise it will scratch, also steel wool works excellant on chrome just make sure you get the extra fine wool
2006 V6 Automatic 2WD CrewCab... HID's, Billet Grill, and some other good stuff "You don't stop doing because you grow old, you grow old because you stop doing" "If at first you don't succeed, call in an air strike" Get them terrorist!
as for vinegar, ive tried it but to no avail. I actually like that invisible glass stuff, it works well (and i swear to the newspaper... its in one of the threads on here)
XEs ROCK ![]() cardomain page:http://www.cardomain.com/ride/2425259/1 itsmynissan page: http://itsmynissan.com/beefy242 gamertag: The Real Johnso Myspace:http://www.myspace.com/cutestshitever I have a truck. It gets me from A to B. Why I spend so much money changing it, I will never know. Is there a cure for this disease? I have no idea what I would be using all my money for if there was a cure. ![]() |
