Try Simple Green. I have waterspots from time to time and Simple Green seems to work even when Windex, etc won't. I started wiping the windows with a chamois cloth before they dry, that way no spots can form.
Sounds Like They Hard Water Spots To Me... Lots N Lots Of Minerals Id Say To Use Lime Away Like Someone Suggested Earlier
^^ a black truck isn't for all people or all locations i am fortunate to have pretty good weather all the time and i always wipe her down every morning to get that over nite dust off of her so she shines like new all the time
2006 V6 Automatic 2WD CrewCab... HID's, Billet Grill, and some other good stuff "You don't stop doing because you grow old, you grow old because you stop doing" "If at first you don't succeed, call in an air strike" Get them terrorist!
Vinegar didn't touch them. I guess Lime Away is the best option.
2000 Nissan Maxima SE 5-spd. Charcoal 99 Frontier 4x4 King Cab V6 SE Black - Gone |
If you act fast, white vinegar does a good job removing water spots. If you leave the spots go for an extended period off time, they can be extremely difficult to get off. The hot sun tends to bake and etch them into the glass. In this case, a more aggressive approach mentioned in this forum will be needed.
Yeah they've been there for a long time. So you guys think that Lime Away/fine Brillo pad is the best option?
![]() If that fails, I sometimes use simoniz glass cleaner
2006 SE KC 4x4 auto ![]() |
Polish the windows with whatever automotive polish you prefer (I like Optimum and Menzerna) with a polishing pad on a Porter Cable Orbital (7424). Once polished, you can seal them up with either wax or an acrylic sealant so the water won't spot as easily in the future.
2005 Electric Blue LE CC 2WD Clarion DXZ765MP Head Unit Planet Audio 6.5" Components Power Acoustik LT480/2 Amp (Works better than I thought it would!!) 1996 Lanzar DC-10 SVC 4 Ohm Sub Mid 90's Orion Cobalt 702 Amp (I like the old school!) Xact Visor Sirius Tuner Harmon Kardon Drive+Play iPod module |
Water Spot Removal
Use Mcquires water spot removal liquid and a buffer. I do this all the time for clients cars. If you can't find it , start by soaking the spots in laquer thinner, then buff your glass with 3m super cut compound, if still present use 1000 grit wet paper to "wet sand" and then follow with your car wax, machine buffed on to reduce water spotting in the future.
'05 Frontier SE 4x4 |
