rubber stuck everywhere!
Well does anyone know the best way to take off rubber from the mudd flaps and my banks exhaust tip because i showed those yota guys whats up i killed the place i wish i got it on vidio !!!
07 Nissan Frontier Avalanche white 4x4 cc lb, K&N 77 series intake, Airaid throttle body spacer, Banks Monster Exhaust, Alpine CDA-9883 Deck, Jl w7 13.5 soon to be lifted a total of 11in!!!! Last edited by StormNISMO : 12-05-2007 at 01:36 PM. |
Driving wasted ? tsk tsk tsk.............
here's my sig.....
You changed your post, so I will change mine.
![]() 1994 Pathfinder Auto 4x4. Mall Crawler. 2007 NISMO KC 6M 4x4 - Gone 2005 SE KC 6M 2x4 - Gone 2002 SE CC 4A 2x4 - Gone Last edited by Inyourface1650 : 12-05-2007 at 03:15 PM. |
driving with any bit of alcohol is just plain retarded... PM AgTitan06 about cleaning that rubber off.......
************************************* your fastest SE CC Auto 4x4- Uprev Tuned ECU http://www.youtube.com/watch?v=bTz2PTYwmnU 14.891 @ 91.73mph ![]() ************************************* |
You can use a bit of gasoline, but with the nissan paint, youll def be getting down to metal. |
goof off... Works good
-Jeremy ![]() 2007 Nissan Frontier SE CCSB 4x4 6spd Its Got Modifications
Peanut Butter.....Seriously
2004 CC V6 4x4 - Shrock front bumper, Ramsy Profile 8000# Winch W/in-cab on-off switch, KC Daylighters, 31x10.50 BFG A/T's, Optima Yellow Top, T-Bar Crank, Calmini Shackles, Low Profile Bump Stops, Cobra CB, 4' Firestick |
here's my sig.....
It works on rubber from the drag strip, so most likely yes
getting rubber off......
I use Laquer thinner for contaminants like rubber, tar ,old stickers, etc... you can also use acetone......both of which are far superior to Goof off and the like, and cheaper too......just after getting the crud off, follow with your favorite polish / wax......
2005 Frontier SE 4x4 |
