Old 05-20-2008, 06:47 PM
lime away/ CLR bad for paint?
ok, before everyone trys to shove bamboo up my finger nails, i searched this earlier and didnt find the answers i needed. i checked out both lime away and clr and they both say do not use on glossy or painted surfaces. so is it safe for my hard to keep shiny black paint or not. What ratio did you use to water, and which lime away did you use, the spray bottle kind or the crystalized kind? Is it necessary to wax my paint after this? thanks for your help, it looks lke my apt complex waters the grass with salt water, water spots suck
Old 05-20-2008, 08:20 PM
Don't use lime away. I've never used it on paint, and I don't want to try. If you have water spots use a 50-50 mix of vinegar and water. And yes, you will have to wash and wax afterwards.
2005 Electric Blue LE CC 2WD
Clarion DXZ765MP Head Unit
Planet Audio 6.5" Components
Cheapo Power Acoustik LT480/2 Amp (soon to change)
1996 Lanzar DC-10 SVC 4 Ohm Sub
Mid 90's Orion Cobalt 702 Amp (I like the old school!)
Xact Visor Sirius Tuner
Harmon Kardon Drive+Play iPod module
Old 05-20-2008, 09:01 PM
Pea-Ta's Avatar
I wouldn't use it =/
just my $0.02
Avalanche 2008 Nissan Frontier SE King Cab 4X2
Old 05-21-2008, 04:49 AM
cctmobiledetail's Avatar
Their is hard water spot remover made by a few companies that I use in my detail business, that works well. Yes you should wax the truck after using the hard water spot remover.
I've heard of folks using clr on paint, but because clr is caustic, even highly diluted amounts will soften and damage the clear coat. I wouldn't advise it !
I would advise parking your truck elsewhere as well as buying a car cover and approaching the apt management and asking if their willing to relocate your parking space to keep your truck from getting water spots, since it's their fault I'd make them responsible !
I use the Mequiars hard water spot remover all the time and buy it by the case !
3M light compound will take off spots as well , but it takes longer this way
3M™ Scratch Remover
Safely and effectively removes grade 1200 or finer sand scratches, other fine scratches, medium oxidation, coarse swirl marks or water spots, and leaves a fine finish. Excellent for hand compounding applications.
  • For machine or hand use
  • Clear coat safe
  • Easy to use
Old 05-21-2008, 07:09 AM
ToddG's Avatar
LOL, good one!
I felt a great disturbance in the detailing business, as if millions of paint jobs suddenly cried out in terror and were suddenly silenced.
I wouldn't use anything not specifically called out for automotive paint finishes unless you're a chemist and know what you are doing. That said, try using a clay bar to get the "deposits" off your paint, works wonders.
2006 SE 4x4 CC, 6 speed, Sunroof, Red Alert
Interior Mods: Kenwood KDC-MP438U, Sirius, Polk Audio MMC6500 (front), Polk Audio DB651 (rear) Alpine PDX-5 @600 watts, Polk Audio DB104 sub w/custom fiberglass enclosure, Gentex Temp/Compass/Homelink Mirror, Weathertech floor liners front/mats rear, ScanGauge II w/blendmount.
Exterior Mods: Silverstar Ultras, Hella Micro DE driving lights, EZDown Tailgate Damper, Extang Full Tilt Tonneau cover, Weathertech side window deflectors.
Performance Mods: Flowmaster 50 Series dual in/dual out (PT# 525554)w/ stock dia. 2.25” pipe, K&N drop in.
Write ups:
Old 05-21-2008, 09:06 AM
Originally Posted by ToddG View Post
LOL, good one!
Clay bar will NOT remove hard water spots , See Above for hard Water spot remover !
Old 05-21-2008, 09:49 AM
ToddG's Avatar
IF that's what they are, I agree. Hard to tell exactly what they are from the description, imo.
Write ups:
Old 05-21-2008, 10:20 AM
Mylt1's Avatar
couldnt find the answer????
checked out both lime away and clr and they both saydo not use on glossy or painted surfaces.
looks like the answer to me.
see above.
05 LE CC 4X4. SUPER BLACK
Old 05-21-2008, 10:37 AM
06blackse's Avatar
When I used to detail cars (for almost 6 years) this is the method I would use, it works and works well, but definitely wax after washing to get back the shine
Current Collection:
06 Honda Civic EX (SI swap w/turbo, wifes car)
06 Nissan Frontier SE King Cab
(3" PRG, Pro comp 8089 Wheels, Procomp Extreme Mud Terrains 285/75/16)
06 Polaris Sportsman 500 EFI (red/black, wife's)
07 Polaris Sportsman 500 EFI (all black, mine)
Old 05-21-2008, 12:48 PM
Darkness posts from the original post "it looks lke my apt complex waters the grass with salt water, water spots suck "
That would BE Hard water !
