Some kind of solvent might work. My dad is big into golf so we have a lot of grip solvent at out house and that will work on just about anything. I don't think it will really harm the paint too bad, but not 100% sure on it. Whatever you do get it off with make sure you wash it really good and hit it with a coat of wax afterwards.
I've heard good things about Duro Super Glue Remover. It's not the cheapest thing though.
Acetone usually works, but i see you tried nail polish remover.
2007 Black Nismo King Cab 6spd 4X4 |
it could of been a non acetone remover. try acetone, but test it under the hood so if it does harm the pain you learn it where you wont see it instead of bare metal in the middle of your hood.
2006 SE kc. 4x4 6spd. Storm gray. calmini 2.5'' lift. 255/85 Maxxis Bighorn(ey)s. De-badged. No person was ever honored for what he received. Honor has been awarded for what he gave. - Calvin Coolidge |
Acetone won't hurt your paint , I've used it hundreds of times, a stronger cleaner, however is Laquer thinner, which I use all the time on thousands of cars. Soak a rag in the thinner lay it on the glue spot and let it sit several minutes, then wipe away and follow with your favorite polish.
