Originally Posted by NISM0
Another great job CCT. I am looking for a good exterior rubber and plastic protectant. I've tried a couple differant products, but I am not satisfied. The ones I have tried seem to bleed onto the paint after a rain storm. Do you have any suggestions? Thanks.........
well ofcourse you can certainly use a tire dressing, but it only lasts for several weeks if using Mcquires Hot Shine. I personally prefer to use a combination of "Rubber lube" ... ( Hard to find ) and or a creme leather conditioner, let dry then followed with a spray leather conditioner to blend it out. the rubber lube or leather stuff lasts a fair amount of time, and doesn't seem to run on the paint nor sling like tire dressing does. as far as plastic protectorant , I assume your speaking about interior plastci and the like, again leather spray works well , if it's exterior plastic, then a spray wax detailer from a spray bottle will work. Hope that helps !
