I was wanting to put a pair of 10's in my crew cab, Possibly under the rear seat. I guess I was wondering what all would work since Ive seen alot of guys on here have done things similar. Thanks
Reasonable 10's fit, not sure anything bigger would without being obvious. I had a Boston 10.5lf down firing on under the drivers rear seat in my 08. Still have the box if anyone wants it, local pickup only though in NH!
A pair of 10's fits almost perfectly under the CC's back seat.
I did quite a bit of research on different sub brands and models, weeding out the models that are too tall to fit in a typical underseat enclosure.
I also paid attention to the efficiency (or "sensitivity") spec of each model. Some models are 10 dB less efficient than others - which means that you need 10 times as much amplifier power to make the most inefficient model as loud as the most efficient.
Another important consideration is surround material. Rubber lasts quite a bit longer than foam.
Sorted by efficiency:
The Boss D10F's looked very good on paper, and have worked out great - I wouldn't hesitate to pick them again.
I have 2 10inch subs under the rearseats. They are Jl Audio TW3s( I got a amazing deal on them on blackfriday). I love my seatup under the seats because it does not get in the way and it sounds great.
