the sales person doesn't know what they are talking about. You just need to get a good set of 6x9's 4ohm they will work just fine...
Thank you, Greg (a.k.a Wizzard005) ![]() Website: http://www.toy4runner.com Photo Gallery: http://wizzard005.smugmug.com Lift: PRG 3" Spacer w/ 1.5 Shackles + 1/2 Blocks in the Rear | Tires: Nitto Terra Grappler 285x75x16 Toons: Pioneer AVIC-F700BT | Eclipse 4 Channel Amp | JL Audio 300.2 | Pioneer Shallow Mount Subs 2x 10"s | Eclipse 6x9 Comps Front | Eclipse 6.5's Rear | Audio Quest Speaker Wiring 4pair Lights: HID's 6000k 9007 Bi-Xenon Headlights | HID's 6000k H11 Fogs Older Cars / Trucks: 2003 Lexus IS300 (Sold) 1996 Toyota 4Runner SAS'd (Sold) 1998 Dodge Ram 1500 (sold) 1998 Toyota Tacoma (Sold) |
we all had 2ohm speakers, at least in the front. This has something to do with the way they wired the tweeters in the dash. But as wizard says 4 ohms work fine. I think some folks have disconnected the tweeters to get back to 4, but must have not.
im new to the forum here but audio is my specialty. in a very simple way of saying this, ohms is a matter of resistance... 4 ohm has more resistance than 2ohms. The way the factory wires them is to get a final ohm load of 2 for less resistance allowing a cheaper way of powering them (the stock headunit). when looking for doorspeakers without amps you need to match what you have in there with your aftermarket cd player (if you get one) if not your speakers are being wayyyyyy under powered and have alot more potential. you did nothing wrong but if you want them louder get an amp because they are being underpowered. if you were to unplug your tweeters the ohms would either go up to 4 or down to 1 depending on the ohms of your speaker. stock headunits arent 1ohm stable and will mostlikely overheat.
removing rear panels?
2008 BLACK KC SE V6 4WD 6-SPEED |
