Do any of you have the XM SureConnect system on your truck. It save you having to change the FM channel while on a trip. It's attached to your trucks stock antenna. Really good thing to have on a trip.
2005 4X2 CC Nismo Auto, Nissan Vent Visor, Nissan Bug Guard, Gibson Catback, Nissan Hitch, 35% Window Tint, UnderCover Tonneau, Silvania Ultra SilverStar Headlights, Optilux Extreme XY Yellow Xenon, Hella FF75 Driving Lights. |
IMO, fm directs are better, and result in a cleaner looking installation, they're available for xm and sirius. as far as the antenna... I cheat, I have the stock bubble looking thing in the middle of my front roof.
'07 Frontier Crew Cab Long Wheel Base LE 2WD |
I have sirius, my antenna route is highlighted in red. From where the red stops it goes into the engine compartment and through the grommet in the firewall to the receiver on my dash. I just used a pair of small flat head screw drivers to put the wire under the windshield molding. It takes some time and patience but you can't see any wires so it was worth it. The only reason I didn't mount it near the 3rd brake light was because I didn't have the deep sockets you need to get it off.
2005 Nissan Frontier SE KC 4X4 - Dynomax Exhaust, K @ N Intake, BFG All Terrain T/As, JVC KD-S32 Head Unit, Kenwood 6X9 5-way 500w Front Speakers, Kenwood 6.5" 3-way 240w Rear Speakers, Alphasonik 360w Amplifier, Towing pkg 1998 Pontiac Grand Prix GTP - K & N, Flowmaster 40s, 180 T-Stat, 3.5" Pulley 1993 Ford Taurus SHO ATX DD - Stock 2005 Arctic Cat ZR 900 EFI - Cpi pipe 2005 Arctic Cat 650 V2 - K & N, HMF Pipe, Dynatek CDI, AC Hand & Thumb Warmers, Odyessy Battery, Warn 2.5ci Winch, AC Rear Bumper, Swamplites soon Last edited by Troy50612 : 05-21-2008 at 11:10 AM. |
Thanks All
So - I ended up going the third tail light route. I bought a long 8mm socket as that size doesn't come standard with any of my kits. $4 at local hardware store. As noted above the removal and re-installation of the screws is the trickiest part. Took me some time to get them lined up and off because my wrench kept bumping into the roof liner. I routed the wire along the top of the window seals and down the passenger pillar. I haven't yet decided where to install the receiver. Trying to decide between under the passenger seat, in the dash or in one of the glove boxes. I know this is personal choice for the most part and will pick something. I am leaning towards the dash because I hope to install a sub and some amps and want to leave the room under the passenger seat free. Thanks again all.
I put my on the floor behind my power outlet / airbag shut off switch thing. Cleaned out my cubby hole now it looks naked.
i have the same set up as you do weehooker, it looks clean enough with the low profile antenna and my reception is better than my wifes car with her factory sirius system
2007 SE CC in Radiant Silver. Kenwood HU with Direct Sirius, JBL 6x9's, JBL 6.5's, Kicker 10" CVT in custom box, Lund Avenger bug shield, SilverStar Ultra SU's, dark tint all around. |
'05 EB CC NISMO 4X4 MODs-Nissan toolbox-PRGproducts. com 3in lift with T\C arms, radflos and Deavers,Bilstien 5125's-265/75R16 Firestone Destination M/Ts-Volant Cold air intake!, Trail Gear Rock sliders ![]() http://www.cardomain.com/ride/2600655/1 |
mine is mounted on the dash as well no issues so far
2008 KC SE V6 4X4 6-SPD |
I've had both XM and Sirius. I had my XM antenna mounte on the dash and had excellent reception. The Sirius antenna had poor reception when mounted on the dash. I had to mount it on the roof for good reception.
2004 XE Kingcab http://www.cardomain.com/id/jonbth |
