question about ohms that need to be dumbed down for me
2 ohm vs 4 ohm? pros cons and sound quality?
Everything I have found on the net seems to be written for electricians and electrical engineers and just gets me confused. Can someone please describe this to me in layman's terms?
Thanks
my spelling and gramar blow. You'll get over it.
09 Fronty SE stock
future mods- 3" sl and 2 or 3" body lift, air intake ( possibly snorkel too) rip out all the carpet and rhinoline it.
Audio- Pioneer 10" premier sub, Alpine M500 amp. Pioneer Premier HU
'06 CC NISMO 4X4
VISUAL MODS: 5% TINT(1% TOTAL ON REAR), SILVINA SILVERSTARS, 9" AMI STUBBI, PATHY SWITCH COVERS, RED LED WINDOW SWITCHES, HELLA 500's ON CUSTOM LIGHTBAR
PROFORMANCE MODS: FLOWMASTER 50 SERIES SUV, AIR BOX MOD, K&N DROPIN, PRG 3" FRONT LIFT, AC 3" AAL, 285/75-R16 DICK CEPEK FUN COUNTRY II, R1 CONCEPTS ROTERS, SS BREAKLINES
AUDIO: ECLIPSE CD5000, CDT AUDIO COMPONENTS, 2 10" ALPINE-S, ROCKFORD FOSGATE PUNCH 325.2, STEP 1 OF "BIG 3" UPGRADE
Run 1 alpine 10" sub with an alpine amp. I'm going for both loudness and sound quality
09 Fronty SE stock
the sound quality differences are minor at best. a 2 ohm woofer and a 4 ohm woofer spec out differently according to the t/s parameters, but its not as easy to say one specific ohm sounds better than another. for all intensive purposes, they sound the same.
ohms sound only be taken into account when choosing an amp. think of it like hooking up a trailer to a truck. you choose the right truck (amp) to pull the right trailer (sub). some amps can pull a heavy 1 ohm load. some cant.
if you get confused on wiring up ohms, there are tons of wiring diagrams available from many sources. RF has a good one on their website, or you can check out the12volt.com
Ohms (impedance) is the amount of resistance a speaker provides to the flow of current from an amplifier. The lower the impedance, the more power will be drawn from the amp, which generally increases the system efficiency and sound output.
So a 2 ohm speaker will generally be louder than a 4 or 8 ohm. As pointed out, this does not affect sound quality, only output levels.
If you go with a lower impedance speaker, make SURE that your amp is designed for that load (impedance) or more current will be drawn from the amp than it is designed for resulting in overheating, blown fuses, or smoke.
Connecting multiple speakers complicates things as there are specific formulas to determine a speaker system impedance depending on whether the speakers are connected in series, parallel, or series-parallel (both). Google searches will locate lots of website with details.
Hope this helps.
Lavarocker
The Following User Says Thank You to lavarocker For This Useful Post:
so then as long as I run a 2 ohm amp and 2 ohm I'd be alright? or is all that based on how I wire it up?
09 Fronty SE stock
You're talking about a single sub-woofer right? In that case there are no formulas or wiring complications, so your fine as long as the amp can drive an impedance equal to or lower than your speaker (load).
Not necessarily true. Some subs are a DVC(dual voice coil). With that said a single(1 sub) 4ohm dual voice coil sub can be wired to 2 or 8 ohms and a single(again, 1 sub) 2 ohm DVC sub can be wired to 1 or 4 ohms.
The Following User Says Thank You to DoubleJ For This Useful Post:
09 Fronty SE stock
wire the coils in series for a 4ohm load and yout good.
and if you decide to add a second sub in the future you can.
'06 CC NISMO 4X4
